Sudden Loss of clutch
I've recently suddenly lost all feeling of the clutch. I was doing a hard pull 1-2 then 3 didn't want to go in. The pedal turned mushy and soft. I park the car and check for any faulty cylinder. The master and slave cylinder are working well. I adjust/bleed the clutch feeling and it works well again. I put the car in reverse and I hear a weird noise and car stalls. I've lost all response on the clutch again, but the pedal works fine. What could be the problem?
Clutch wasn't doing bad before the problem happened.
Car makes close to 450AWHP
Clutch Spec:
Clutch Spec:
- ACT heavy duty clutch and pressure plate
- ACT pro lite flywheel
Remove PP bolts via inspection cover? Check.
Use a grinder to cut teeth away from TOB to get pressure plate out of trans? Check
It took half a day to get that clutch out.
Yeah....I can laugh about it now...
okevolutionVIII
14
Nov 11, 2007 08:20 AM
