Camshaft options
Old Mar 25, 2021 | 05:53 PM
Nicolas's Avatar
Camshaft options
I am in the process of building my 4g63 2.2LR (evo 8) and i own a set of cosworth M2 and a set of Buschur 272. Should i use one of these two sets or go to S3? G30-770 on 93 pump gas mainly.
I have read the dsportmag comparison a thousand times However M2 were not tested and although they say S3 is for applications above 800whp they seem to do better earlier than i thought. At just 5000rpm
Old Mar 26, 2021 | 04:19 PM
hutch959's Avatar
i have a 2.4 with s3's.
love them
Old Apr 2, 2021 | 01:15 PM
Nicolas's Avatar
Noone has ever tried the BR 272 or has gone to gsc s3 from 272 (any cam) with a garrett 30 series turbo or at least an fp red??!!!
Old Apr 5, 2021 | 09:40 AM
schuhie's Avatar
This depends on the goal of the car. I have run my M2s and GSC S2s on a high comp 2.0 with an FP Red and absolutely love it. I wouldn't move to the S3s because I wouldn't want to give up the spool RPM.
That said, my car is pretty much a street car. If you plan to drag race it more than street it, go big lol.
Old Apr 5, 2021 | 12:06 PM
Project_Broke's Avatar
I run S3s on an AGT 55mm (Red), love them. Spools a tad slower, but they pull to redline.
Old Apr 5, 2021 | 12:38 PM
Nicolas's Avatar
street car not drag. what difference did you notice between S2 and M2 on the same setup?
when i went from HKS 280 to M2 272 on stock turbo i did not notice any difference in spooling. However HKS are known to be mild compared to the competition.
Old Apr 6, 2021 | 07:58 AM
schuhie's Avatar
I didn't notice any real difference in spool between the M2s and S2s. The S2s do seem to make a little more up top but I switched tuners too so that's another variable.
I would have never switched away from the M2s but my head got messed up and I got a really good deal on a built head with the S2s in it already. I actually still have the M2s on a shelf lol.
Old Apr 6, 2021 | 10:01 AM
Nicolas's Avatar
most probably i will sell the Buschur 272, keep the M2 272 and call it a day
Old Apr 6, 2021 | 04:39 PM
CurseDSM's Avatar
Id go s3 or Kelford 284s or 88s depending on your intake setup.
Old Apr 6, 2021 | 04:52 PM
Nicolas's Avatar
ported head, stock valves, ported skunk 2 with 65mm TB
Old Apr 7, 2021 | 01:26 AM
CurseDSM's Avatar
Then s2 cams.
Old Apr 7, 2021 | 10:20 PM
Jonno99's Avatar
S2s
Old Apr 8, 2021 | 04:38 AM
Nicolas's Avatar
one thread i found was by mrfred S2 vs R2
My understanding is that there is not much difference and most probably the same will apply with the 2 sets i currently have
Old Apr 8, 2021 | 05:30 AM
schuhie's Avatar
Yea, there is almost no reason to move from the M2s to the S2s other than a little extra way up top. For a street car, I'd just run what you have and carry on.
Old Apr 8, 2021 | 02:47 PM
CurseDSM's Avatar
I disagree with this being the R2 cams were designed for stroker motors and or larger displacement. Being they were similar to the s2 cams, they offer more lift which on a 2.2 you can actually use it. Your gaining displacement which will move more exhaust gas so why not utilize the extra lift to get the gasses out of the engine better. The only downfall would be stock size intake mani. Skunk mani is a good mani, but with something like a new JMF mani or a Magnus mani your allowing that lift to get more air into the engine. It doesn't matter if its a street car or a full out drag car you want to use as much powerband as you can to make the power. So with that said I will change my thing to r2's
