Stalling problem
Stalling problem
Hello,
I've been having some idle/stalling problems. Cleaned out IACV, and car drives fine when it's cruising, but once I come to a stop, there are times when idle drops to 4-500 and car seems like it will stall out. Worse when I turn the steering wheel while car is barely moving (going in and out of parking lot), or when I press and release the clutch constantly while giving it gas (like when I'm trying to park on a hill). It's never stalled out, until today. Did it twice, and car was able to start up fine and drive fine afterwards. I've read that a bad MAF or MAP sensor may cause the rough idle and stalling, and was wondering if anyone else on here has had similar issues or know a solution. I havent tried putting new sensors yet, figured I'd try to find some answers before buying.
Thank you!
Thank you!
Other modifications are:
Arp studs
Injector dynamic 1250cc injectors
Walbro 255 fuel pump
Exedy clutch disc and flywheel with act pressure plate/monoloc
Real street oil pump
Zerotick lifters
Stm balancer shaft eliminator kit
Stm oil cooler
Stm water pump
Mishimoto front mount intercooler and pipes
Egr delete
Oem bov
Aem boost/afr/volt gauge
K&n intake
Radium high flow 6 micron in line fuel filter
BulletWalker
25
Mar 8, 2008 08:23 AM
BluByYouEvoVIII
Apr 2, 2007 10:55 AM
