4G63 Manley H-Tuff rods
Old Feb 15, 2024 | 10:06 AM
BrentD's Avatar
Post 4G63 Manley H-Tuff rods
Goodmorning,
i have a fully built 2.0L 4g63 with the following setup:
- Wiseco HD pistons
- Manley H-Tuff rods w/ ARP2000 rod bolts
- L19 headstuds
- Mainstuds
- GSC S2 camshafts
- GSC valves
- Kiggly Beehive springs
So my limiting factor in this built are the rods with the rod bolts.
I rev the engine to about 8500 rpm.
From what i've read and hread the H-tuff rods are not strong enough for over 700hp.
Even though the sales pitch says 750hp for the arp 2000 and 950 for the arp 625+'s.
Has anyone used these rods in 700+ applications? Manley doesn't answer any of my e-mails.
I plan to keep torque to 550 ft lbs MAX anyway.
Any input is appriciated.
Old Feb 15, 2024 | 11:24 AM
schuhie's Avatar
I haven't used them but I think your best bet is to keep trying to get ahold of Manley if you can.
That said, I did a quick google around and see that with the standard ARP2000 rod bolts, they should be limited to about 750 crank horsepower.
You don't mention if the numbers in your post are wheel or crank but there is a pretty large difference; something like 25-35%, between those 2 values. Taking their 750 crank horsepower rating and applying the estimated driveline loss, they max out somewhere between 487-562 wheel horsepower applying 25% and 35% lose respectively. Honestly, those numbers seem a touch low to me but Manley is the best place to get that answer.
Old Feb 16, 2024 | 05:55 AM
Ayoustin's Avatar
Power ratings are a CYA and requires some reading between the lines. Rod bolts only fail under tension, the only time a rod sees higher tensile force is from higher engine speed, so if you aren't increasing your redline then better rod bolts are not going to make your engine magically hold more power.
Would I trust the H tuffs to 950? Probably not, but it really depends on where peak power is at what RPM as well as what peak torque is since torque is what kills rods.
Old Feb 20, 2024 | 08:25 AM
schuhie's Avatar
100% they are a CYA but its a starting point. Yea, the rod bolts thing it always a little funny to me too but I figured I'd quote it as they have it posted for info.
blkct9
Oct 26, 2023 06:22 PM
maikcat
Nov 16, 2015 10:55 AM
RealStreet
Aug 22, 2012 02:03 PM
gt42r
74
Mar 7, 2012 12:46 PM
boczo777
May 30, 2011 03:09 PM
