Evo 8 Pressure test
Evo 8 Pressure test
So i did pressure test for my evo 8 that has around 180k km and the results were-
Cyl 1 - 180 psi
Cyl 2 - 160 psi
Cyl 3 - 170 psi
Cyl 4 - 140 psi
Tests were done with warm engine
Can someone tell if i have to worrie about it and start thinking about rebuild or is this fine
Cyl 1 - 180 psi
Cyl 2 - 160 psi
Cyl 3 - 170 psi
Cyl 4 - 140 psi
#4 seems a bit on the low side. Re-run the test but add a cap of oil into the cylinder to see if that pulls up the number. That will let you know if its rings or in the head.
A leakdown test would be a good idea too.
bostonhatcher
Jun 5, 2010 01:59 PM
Sloop
May 13, 2004 11:31 AM
