should i buy downpipe or not....
Old Apr 29, 2004 | 10:03 AM
tweakdsm's Avatar
i got catback with h-flow cat and other goodies, i know the stock downpipe flows good, so i was thinking its time to buy downpipe...but is it worth it? does dp gives u any hp?
Old Apr 29, 2004 | 10:15 AM
ev8sive's Avatar
Yes, my car hauls *** now with the new DP. I have the RS-R Downpipe.
Old Apr 29, 2004 | 10:22 AM
evo542's Avatar
definetly it's worth 10+hp
Old Apr 29, 2004 | 10:23 AM
boomn29's Avatar
I have a 2.5" catback...
Could I get a 3" dp and HF cat to mount to my existing cat-back?? I know it's not perfect, but I don't want to rebuy cat-back. It's still better than what I have currently right???
Old Apr 29, 2004 | 08:49 PM
3K's Avatar
3K
boomn you should not neck down from a 3"dp into a 2.5" catback. go with 2.5 all the way. Or 3" all the way.
I'm also contemplating whether or not to get a dp. Because I don't want to get a dp now only to have to change it with an upgraded turbo kit.
Old Apr 30, 2004 | 05:57 AM
tweakdsm's Avatar
does the sound change with the downpipe?
Old Apr 30, 2004 | 06:00 AM
nastea1's Avatar
a little bit, but the power gain is phenominal! it is definately one of the best bangs for the buck
Old Apr 30, 2004 | 06:01 AM
boomn29's Avatar
Would it really hurt anything to start 3"...then neck down to 2.5" from the cat-back? I figured it would be better, performance wise, then having the stock DP and Cat I have now. Plus, in case I decided on cams or something bigger later, I could upgrade the cat-back to 3" later and be done. Or should I say 2.5"??
Also, won't a downpipe add some volume?? I'd like a little more myself.
Old Apr 30, 2004 | 03:26 PM
xstang's Avatar
I'm not convinced about the power of the downpipe either. I am saving that for one of my last mods. I have yet to see dyno numbers that justify dishing out 300 for a 3inch downpipe. Do some reasearch... I honestly believe the gains are minimal... Al was able to get 289HP with just a catback, MBC and flash. The stock cat and catback are the big corks in the system... If anyone disagrees, please post a dyno graph to prove your case.. I've read about every thread I could find on this subject...
Catback and testpipe are worth about 25-30 HP withthout swapping the downpipe... Don't think you will get much more out of the system... 2-5 Hp is not woth $$$300
I went with a Bushur's 3 inch catback that bolts to the stock pipe... In addition I got the UR test pipe to hook to that... If I ever decide to go 3 inch all the way, I can cut off the flange on the BR... 2.5 is plenty for the stock turbo....
Old Apr 30, 2004 | 03:32 PM
Hungbee112's Avatar
An upgraded downpipe is well worth your money. Your turbo is going to spool up considerably faster and sooner in the power band. I got my downpipe from lancershop for 180, and it works just fine. no need to dish out 300 if you don't want too. Get a used one from a private seller, I've seen guys sell their downpipes on here for 150.
Old Apr 30, 2004 | 03:47 PM
boomn29's Avatar
Tell those guys to PM me then! I'm still looking the used route!
Who sells a 2.5" HF cat anyways?
Old Apr 30, 2004 | 03:51 PM
ev8sive's Avatar
I picked up a used RS-R downpipe which eliminates the Cat at the same time. Only other exhaust mod was a buschur muffler delete. With the addition of the downpipe I noticed a HUGE difference in spool-up, mid-rage, and top end power. I am still running the stock piping after the downpipe and before the muffler delete.
It sounds MEAN too
I will be adding a DSS-Racing 3" Cat-back when I get my car back from the shop.
Old Apr 30, 2004 | 03:52 PM
boomn29's Avatar
It sounds MEAN too
Your downpipe replaced the cat-con too? Does it mount up the to the piping then? If so, where did you get it??
Old Apr 30, 2004 | 03:53 PM
mifesto's Avatar
hey hungbee112, how is the fitment of the Lancershop DP? is it pretty close to the oil pan? does it hit anything, rattles? any leaks?
Old Apr 30, 2004 | 05:05 PM
absinthe's Avatar
first off
get the bushur 2.5 in DP or a similar piece, more power/cheaper on your set up than most 3in pipes, because you wont have the in pipe turbulance issues that can come with a 3in pipe and they are much closer to 200 than 300 bones
The correct DP with a high flow cat and cat back can be worth way more than just a cat back/test pipe because of the effective preasure difference created by the free flowing exhaust. DP on a stock car is rumored to be worth 10hp, so one would reason it should be worth at least that probaly more.
Hehas a highflow cat already and set with the right DP these make almost as much power as a test pipe (ask al if you dont believe me) so the DP is the next logical mod for him.
