CEL after installing pump and injectors
Old May 4, 2004 | 10:07 PM
mrdecibel's Avatar
Installed Walboro pump and 680 injectors. Drove car a few miles and CEL came on. Came home and disconnected battery for a bit, CEL went out. Unfortunately car does not want to idle worth a damn. I am using SAFC to control fuel. Any insight on this would be greatly appreciated.
Old May 5, 2004 | 04:25 AM
mrdecibel's Avatar
Can someone please chime in?
Old May 5, 2004 | 04:42 AM
jerastan's Avatar
have you leaned it out a bit down low to get the idle back?
Old May 5, 2004 | 04:47 AM
4G63>OOOO's Avatar
Um, what are you running for engine management?
With no other changes, you will run richer than Bill Gates and your car will be slower, you will probably foul plugs (if you haven't already) and the car will generally hate you.
I do have an SAFC-II that I'm not using anymore, if you need it. PM me
Old May 5, 2004 | 04:58 AM
mrdecibel's Avatar
I am running SAFC, I am using settings provided by Buschur. To get it to idle somewhat decent I have to set 800 point for -5 compared to -12 as suggested by Buschur. Since I reset the ECU do you think that has something to do with IDLE changing afterwards? Not sure of why the CEL came on.
Old May 5, 2004 | 12:26 PM
992gnt's Avatar
If Buschurs settings at 800 rpm were -12, you need to go leaner (-15 to start maybe) not richer (-5). That's your problem, you're way too rich. Re-setting the ecu will allow it to re-set fuel trims and it may idle better than before, but I'm guessing you're still really rich. Be careful making changes you can't monitor with o2 voltage or egt's though, it's real easy to cook your engine if you're not sure what you're doing.
Old May 6, 2004 | 01:32 PM
bbyEvoGirl's Avatar
I went to the dealer because I have always thrown a cel for po300, nut when I went to check this last time he said that it was running lean at idle but rich through alll the gears, I have the 680's and fuel pump cams exhast and boost controler. It's probaly nothing. go get you code checked
