Special ECU Reset Vs. Regular ECU Reset
I recently read a thread posting by VishnuTuning about how there is a special way to do a sort of ECU reset in a way that gains you a little power on the WRX's .. Anyone know anything about this in regards to our cars.???
I have posted the thread i read here...
Thanks
This was on NASIOC.. it is for SUBARU's Only...
Just a little trick that has been shown to accelerate the factory ECU's ignition timing learning process.
Background: There is something called "Ignition Advance Multiplier". It represents, by some complicated algorithm, the average learned positive knock correction applied to the ignition maps. It's represented in 1/8th degrees increments. 1 being the lowest and 16 being the highest (1/8 to 2 degrees in absolute terms).
The "happier" (knock free) the car is, the higher the number will be. Conversely, the lower it is, the more knock prone it is. This number, after ECU reset ore ECU swap defaults to 8 and usually creeps up to 16 (if well mapped) through normal driving. Depending on driving characteristics, this can happen within a few hours or a few weeks. Well, here's a way to make it happen in about 5 seconds ....
First: With the car fully warmed up, reset the ECU. This can be done by killing power the ECU or by simply pulling off the neg. battery terminal and pressing the brake pedal for a couple of seconds.
Second: Drive to a nice open road without traffic. Don't go on boost until you get there. Put the car into gear (3rd gear works the best) bring the revs up to 2600rpm. Push the go pedal down slightly so boost stays right around 2-4psi. You will need to MAINTAIN 2500rpm and 2-5psi for approx 5 seconds. You can do this by left-foot braking gently as to prevent acceleration. During these few seconds, the advance multiplier (which you can't see so you'll have to trust me) will go from 8, to 12 and then to 16. Works like a charm. And on our reflashed ECU, is worth an immediate 10-20 horsepower
In an attempt to save a lot of dyno time between reflashes (when the advance multiplier resets itself), I do this little trick after every reflash. In a typical dyno session, it's not unusual to reflash the same car up to 5 times. On the dyno, all I need to do is tell the dyno to hold revs to 2600rpm. Then I just lay on the throttle until I see a few psi of boost... Bingo!
Warning: This little trick artificially speeds up the learning process. This is only a good thing if the re-mapped ECU is mapped properly. If there are trouble-spots where knock is present, this trick will make it even more present. So be careful!
Cheers,
shiv
www.vishnutuning.com
Thanks
Cheers,
shiv
There is no analagous reset for EVOs. Just remember that just after a reset, the EVO defaults to its high det fuel and timing maps (it runs super-conservative). After 3-4 seconds of knock-free on-boost operation, it switches over to the regular fuel/timing maps for max power. Far less tricky to play around with than Subarus.
Cheers,
Shiv
Cheers,
Shiv
