ARC box or Apex'i filter w/ pipe?
Exactly as the title describes, ARC box or the Apex'i filter with a suction pipe i.e. cusco pipe... which would provide better gains with or without S-AFC?
it all depends on your mods. if you still run the stock turbo w/ maf, stick w/ stock. if you've upgraded to a map sensor and bigger turbo, get one that can block some heat from the filter. as far as the sound goes, any time you go w/ an open air filter the sound of the turbo and the bypass valve increase a but load. i ran the hks suction for a while and it was LOUD. however, once i put my stocker back on i gained an *** load of torque back. it's been hashed over and over here, but you better have engine management, and the know-how to tune around the filter that's pushing way too much air throught the maf.
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
You need to check out the new Apexi intake box for the EVO. It looks great and it isn't too much $. Here is the link.
http://www.apexi-usa.com/news.asp?ID=64
They have it pictured on a WRX and an EVO.
