Evo aluminium drive shaft!
Old May 13, 2004 | 05:11 AM
chuntington101's Avatar
Just thought some of you out there would be interested in this!
Nice work and a reasonable price!
http://www.driveshaftshop.com/item9507.ctlg
Old May 13, 2004 | 05:19 AM
metaphysical's Avatar
Registered User
Won't fit an Evo...
Old May 13, 2004 | 07:20 AM
T()()L's Avatar
And why is that so...?
Seems to me it will be manufactured as soon as they get some samples.
Look: http://www.driveshaftshop.com/MITSU.ivnu
Brg Nick
Old May 13, 2004 | 07:32 AM
slt's Avatar
slt
this along with its torsional properties (steel shaft twists about 5 degrees, this twists 19-20 degrees) will save the output shaft from the harmful shock factor that breaks the shaft
Interesting. How much difference does knocking off 10lb from your driveshaft make?
Old May 13, 2004 | 07:46 AM
03EvoVIII's Avatar
I can't remember exactly, but I think it was every one pound of rotational mass reduced you get back 2hp. So (if I remembered that right) you would get back 20hp. Remember this isn't additional hp, it is just not wasted anymore turning your driveshaft.
Old May 13, 2004 | 11:04 AM
maki's Avatar
800 bucks for possible 20 hp, i dont know
Old May 13, 2004 | 11:10 AM
2GDSM's Avatar
I wouldnt go as far as to say 20hp, but it does have a similar effect as a lightweight flywheel. An old college buddy of mine put one on his Miata a few years back and it definitly revved quicker. I am also 99% sure that he got it at the driveshaftshop too...I'll ask him, but if its the same palce, they make quality stuff.
Old May 13, 2004 | 11:36 AM
T()()L's Avatar
Hey....guess the aim for those kits ain`t for power gain so to speak,BUT i f you have the power already and you snap you`r shafts then you might be looking for those guys,be aware of you`r AYC´s and diffs though.
Edit: spelling
Brg Nick
Old May 13, 2004 | 06:40 PM
992gnt's Avatar
Driveshaftshop makes awesome stuff. I had some of their front axles and hubs on my Eclipse.
Old May 13, 2004 | 10:24 PM
AMS's Avatar
AMS
It's not only about shaving off some weight. The AL will twist a little and saok up some of the shock loads we are experiencing on hard drag launches. I'm the one who has been talking with Driveshaft shop and they have a set of our axles and a driveshaft to prototype. The goal here is to reduce transfer case breakage, by allowing the driveshaft to take up some of the initial shock load during a launch.
Old May 13, 2004 | 11:15 PM
Creamo3's Avatar
Very good idea, now let's try and get a carbon fiber drive shaft made like the rx-8
Old May 14, 2004 | 04:46 AM
I know it will help some of the guys in the UK. they always seem to be distroying thier rear diffs, so if the shaft can take a bit of the strain then that can only help. wonder how much wbhp the thing can take????
Chris.
Old May 14, 2004 | 04:52 AM
EVOeight's Avatar
I just got a reply from driveshaftshop.com. They said they are just about finished making axles for the EVO and will start on the drive shaft very soon. I will be one of the first to buy one of these, I will post my opinions when I get it installed...
Old May 14, 2004 | 04:57 AM
MYEVO8U's Avatar
Very nice.
Old May 14, 2004 | 09:07 AM
AMS's Avatar
AMS
I'm also working with a company on a CF driveshaft. The problem with the EVO8 driveshafts is the yokes and the CV joints. With the DS angle we can't do a single piece DS so it must be at least two pieces. Custom yokes and hangers might have to be made. I'll keep everyone updated on progress.
Regards,
