What should the compression test results be.
Old May 13, 2004 | 08:51 AM
Sloop's Avatar
I was wondering what the compression of our engines should be in all 4 cylinders running about 15-16 PSI. I am running lower boost until I can have the car tuned properly. I am also keeping the car off boost until it is tuned.
Thanks
Old May 13, 2004 | 09:16 AM
OnlineAlias's Avatar
Your question doesn't make sense...boost pressure has nothing to do with compression, unless you are talking about cylinder pressure while the car is running.
Old May 13, 2004 | 09:53 AM
Sloop's Avatar
Sorry, cylinder pressure is what I want.
Old May 13, 2004 | 09:56 AM
Why would you need to know that? I'm sure someone has the answer, but, I mean, why do you ask?
Old May 13, 2004 | 10:12 AM
1QWKEVO's Avatar
do u want to know how much boost the cylinders can hold? (ie headgasket, etc..)
Old May 13, 2004 | 10:16 AM
mayhem's Avatar
compression ratio is 8.8
Compression (w/warm engine and throttle fully open) should be 163psi. Minimum is 138psi.
Old May 13, 2004 | 11:19 AM
Sloop's Avatar
Mahem, Thank you. Mine was 150 on all 4 cylinders.
Old May 13, 2004 | 11:31 AM
WhosEVO's Avatar
I just did a compression test last weekend.....190psi all across.
pls keep in mind that my number may different than yours cuz we use different guages.
When I use the same guage to test my ITR motor....it read 255 psi
I guess that's the different between high compression and low compression motor
bryonboals
Aug 4, 2013 06:41 PM
Enzo1089
56
May 19, 2010 06:25 PM
YaroRS
14
Aug 29, 2009 02:28 PM
Ev0cRaZy
Feb 9, 2008 02:12 PM
trinydex
26
Oct 13, 2007 01:16 PM
