What WHP will be generated by these mods????
Old May 23, 2004 | 11:06 AM
evo542's Avatar
looks very good for your current setup, what kind of dyno is it?
Old May 23, 2004 | 11:40 AM
Jonasan50's Avatar
Looks like you get pretty rich as you go up in the rpm's... You can still find more power up top if you wanted... Nice numbers though, good luck, and have fun...
Old May 23, 2004 | 08:34 PM
umiami80's Avatar
Originally Posted by 1QWKEVO
correct my if i'm wrong but that says 333 whp not 404 whp
Today 12:29 PM
Probably refering to this.....
Originally Posted by umiami80
hks 272
Stock intercooler
Buschur upper ic pipes
660 CC injectors
Fuel pump
Boost controler ( hallman )
K&N airfilter
Buschur 3" turbo back
, made 404WHP, ran 11.7, Does not get much better then this for the stock turbo.
Simple, this man Runs the AEM EMS, easilly worth 30-40WHP accross the board. ALso has IC Piping and I think an underdrive pully. His setup is leaner too, my setup allows a richer setup, I am getting IC pipes soon and then a Pully with my clutch setup if I ever get through my stock clutch.
