SAFC2 vs. BuschurFlash
Old May 26, 2004 | 11:27 AM
sirploppy's Avatar
Question SAFC2 vs. BuschurFlash
I searched the boards but really could not find a definative answer. I am thinking of getting the Bushur Stage 1 setup soon. I know there is the option of getting the Buschurflash or the SAFC-2. Which One to get?? I will most likely stay at stage 1 for a while. Is there a substantially flatter torque curve with the flash? Does the SAFC provide better top end? Any dyno charts to compare?
Was going to post this on the Buschur boards but it appears they are down...
Old May 26, 2004 | 11:33 AM
Blak94GSX's Avatar
The AFC is a tuning tool, while the Buschurflash is a fixed map. They do 2 different things. So this is like asking which is better, Nike shoes or an Adidas jersey.
Ideally you get both, though I would start with the Buschurflash. The flash gives you better timing, and then the AFC can be used to fine-tune things a bit if you want to run high boost (25PSI) and some race gas. You would run the flash by itself for the street with the AFC zeroed out basically.
