injector wiring
injector wiring and other questions
hi, anybody know the wiring on the fuel injectors
for some reason I need to know which wire on the injector is switched.
I need to hook up a signal wires to the injector's wires and it is important for me to know which one is the switched and which one isn't.
thanks
Bruce
thanks
Bruce
just about done plumbing and wiring a new water injection system on my evo. at this stage I can only hope everything is connected correctly.
got the pump and all its hardware mounted in a little niche by the bottom of the windshield water tank, so except for some wiring bundles the engine bay looks unchanged.
still need to mount the jet in the intercooler pipe and connect the injector wires and tap into a switched lead for power.
put the fuel injector/ water injector, computer in the ashtray so I can flip up the lid and see if the lights are right. Only one little led indicator/monitor mounted on the dash, but it is small and insignificant.
while I have this busy thread going
I need to find an ignition switched power source to activate the relay on my WI system. Anyone know where there is a good tapable line close to the main fuses and air cleaner in the engine bay?
thanks
thanks
silverevo05
Sep 1, 2010 10:12 AM
TREVORSEVOVIII
Jan 6, 2008 10:07 AM
dudical26
16
Jun 6, 2007 12:13 PM
