BOV & upper IC pipe Question
Old Jun 26, 2004 | 05:47 PM
en1gma19's Avatar
I just recieved my upper IC pipes from Buschur. I already had the Greddy Type-s BOV with universal flange. My question is this. the universal flange has a 2" diameter and the hole on the IC pipe is only 1 1/8". Do the flange and the hole on the pipe need to be the same size? Do I need the "Evo Kit" flange for the Greddy Type-S and if so, does anyone have one they are selling? Thanks
Old Jun 27, 2004 | 11:02 AM
rpm-evo's Avatar
Hey what intake are you running with the Buschur pipe? I am running the K&N typhoon with the forge dv and want to know about fitment issues. Sorry I don't know of an evo kit for the type-s sounds like a run to pep boys or home depot. Since it has the flange am I unable to run the forge dv? Can you just use the stock tubing? I can not tell from the pics on Buschur's website.
Old Jun 27, 2004 | 11:12 AM
MalibuJack's Avatar
If you want to run the Forge DV, I came across an adapter flange for a 1G that you might be able to make work on Ebay.. search for 1G BOV flange its $20 and might do the job for anyone with Buschur intake with the 1G flange on it (and doesn't feel like zipping off the flange or making changes)
Old Jun 28, 2004 | 12:58 AM
odie3283's Avatar
my friend bought the Turbo XS RFL, got the 1g adaptor kit and it works fine on the Buschur pipe...That might be something to look for
or if you can weld, then i'm sure you could do something...then again you wouldn't have asked us
eh...have fun, just run the 1g BOV...you can hear it
