Higher injectors without tuning ok?
Old Jul 6, 2004 | 09:29 AM
NRG's Avatar
NRG
Is it safe or ok to have for example 750cc injectors and fuel rail put in without a piggyback computer or reflash? Will that result in a rich condition because more fuel will be delivered?
Old Jul 6, 2004 | 09:30 AM
leonard_shelby's Avatar
I'm not sure how it could not result in a rich condition.
Old Jul 6, 2004 | 09:31 AM
tama_mog's Avatar
yes....that will definitely run a lot richer....I wouldn't recommend driving around with it too much without tuning, you'll just foul up the spark plugs.
Old Jul 6, 2004 | 01:25 PM
plokivos's Avatar
Isn't the EVO already running rich? It's drowning time...
Old Jul 6, 2004 | 01:29 PM
yup
Old Jul 6, 2004 | 01:37 PM
WildRice's Avatar
Your fuel management will be changed in that the injector duty cycle will be lessened for a given flow rate. The O2 sensor will still operate fine to control the a/f in the closed loop but you may experience idle difficulties.
Old Jul 6, 2004 | 01:44 PM
BadazzCR's Avatar
Car will run at part throttle cause the ecu uses the 02 sensors to adj the fuel. But once you go past about 60% throttle the ecu stops reading the o2 sensor and goes off a base map that has fuel settings set permantaly. Which will cause your car to run very rich and break up once in boost from being to rich.
