how much are the Mitsu. Spark plugs?
me too..what problems do you have? my problem is that the engine lags around 4-5 thousand rpm...like it would rise then stop at 4500rpm...i dont know the problem..i checked the intake, the diverter if its plug in tightly and i check my downpipe..i am curious if the spark plugs would fix the problem
I am having a similar problem....my car runs fine until it gets hot.....then the as soon as the heaviest boost starts to come on the engine feels like its cutting fuel....in some cases the engine won't even rev all the way to redline. Its screwed up...they have replaces the wastegate syllanoid and that did nothing...they also told me the blow of valve had gone bad...which it hadn't. I think it was something to do with the ignition
i have another thread that I started concerning the problem I am having..there are all kinds of possibilities.....how many miles do you have on your car? Have you ever gotten an popping/backfire noises when you stay on the gas when its lagging....or any weird engine noises?
What are the cheapest plugs that would work evo...and where could i get them??
Originally Posted by EvolvedDSM
OEM plugs run about $20-$25 each. For 1/10 that price you can pick up some NGK BPR7ES plugs and probably have better luck. I've been using them for years and they work great.
chmodlf
Feb 18, 2006 04:37 PM
The Emperor
Jul 26, 2004 08:25 PM
