View Poll Results: What is the best Short-Throw shifter for Evo VIII
LS (Lancer Shop) Short-Throw
17
8.59%
B&M Short-Throw
92
46.46%
Perrin Short-Throw
19
9.60%
Kartboy Short-Throw
45
22.73%
Megan Racing Short-Throw
25
12.63%
Voters: 198. You may not vote on this poll
What's the best short-throw shifter?
Old Jul 21, 2004 | 07:47 PM
v8killer's Avatar
thanks for the feedback! I really don't like the stock shifter at all... I will try some bushings and some bg syncroshift from Lancershop... anybody try any of this?
Old Jul 21, 2004 | 08:17 PM
boks's Avatar
I've got a Kartboy SS and brass bushings from Lancershop. When I first installed them it just felt different, and I couldent tell if I liked it better or not. While it is a shorter throw, it takes a bit more muscle to shift. Now that i've gotten used to it and gone back and driven on stock I would say that I definately like it better. Havent dared try any other fluid but stock.
Old Jul 22, 2004 | 03:05 AM
Sentinal's Avatar
The stock shifter feels pretty short already. How much shorter you wanna go?
Drive a 350Z or honda S2000 those are short for stock Evo stock shift is way too high for a serious sports car.
Old Jul 22, 2004 | 06:45 PM
v8killer's Avatar
I agree, that's what I was saying above. Our shifter is long and way down on the floor. I know our car wasn;t originally designed for sport cars use, but it is still lacking IMO
Old Jul 22, 2004 | 07:43 PM
prowler's Avatar
Add the NSX to that list, that gearbox is great!
Old Jul 25, 2004 | 01:27 AM
trinydex's Avatar
the stock shifter is pretty sticky, that's what i didn't like. i got the speed source brassh shift cable bushings and it was kind of a ***** to install. had to sand down one of the bushings because of poor fitment. they include the sandpaper tho, but i think they try to cya by saying the sand paper is there to "take off anything on the pin that might inhibit the bushing from installing" it's actually to sand down the bushing so it will fit in the ring.
it improved feel a lot, but there is a bit of additional effort shifting into 5th.
that outta the way, you failed to includ ethe b&m precision kit, which comes with aluminum shifter base bushings. anything that shortens stock throw is gonna create more effort, but if you insist on the shortness, i like this kit a lot, have it installed in my car also, as long as you follow the how to that is posted up here and you're careful with your dremel cuts ect (measure twice cut once), everything should be fine.
Old Jul 25, 2004 | 09:41 PM
marksae's Avatar
Damn, that's the exact problem I had when I installed the Speed Source bushings into my 2g GSX. It felt like glue going into 5th, but all the other gears felt a lot better. I have a set of the Kartboy shifter cable bushings on my desk and don't want to put them on now.
I think the ideal solid shifter bushings should use spherical bearings. Now if only a vendor will make one for us! The cable ends that meet the shifter use spherical bearings. The tranny end should use them too!
Old Jul 25, 2004 | 11:55 PM
trinydex's Avatar
after putting in the shift kit today and driving a lot more 5th is still a bit gluey but the shift is so "straight" it's great, i don't have to worry about missing and all shifts are much more precise. reverse is another story, kinda gotta get it in this certain spot for it to get in there, which is actually bad since the evo's radius sucks and i can't use ebrake to turn ALL the time :].
Old Jul 26, 2004 | 04:26 AM
Jadiem's Avatar
the last thing you want to do is buy a cheap short shifter.... by doing this you'll miss gears alot more and it'll feel like your never in gear... worthless mod if you ask me... just do bushings and fluid
Old Jul 26, 2004 | 04:44 AM
Captain EVO's Avatar
As inexpensive as those bushings are, why not try stock w/bushings and see if you still want to try a short throw?
Old Jul 26, 2004 | 05:13 AM
Rez90's Avatar
i have the B&M and i'm happy with it
Old Jul 26, 2004 | 06:32 AM
Zeus's Avatar
Wow, sorry yours didn't fit... I'd bet it was the ring vs. the bushing though. Mine went in without any effort... made the action like I'd hoped it would have been from the factory. I also used anti-seize to prevent future problems with dissimilar metals.
Old Jul 26, 2004 | 12:48 PM
trinydex's Avatar
yeah it was bushing vs ring, only the small one, the large one was coaxed in semi nicely, i used wd40 up the until my whole engine bay smelled like it (or maybe i just got it up my nose) but after the sanding everything was kosher, so no complaints, at least none that are worth noting.
Old Jul 27, 2004 | 11:52 AM
texasevo8's Avatar
My friend has a rsx-s, he is about to buy a revo short-shifter kit. But it is a complete replacement not just a rod. Has anyone heard about something like that for the evo
Old Jul 27, 2004 | 01:49 PM
trinydex's Avatar
yeah they make those for hondas but none for evo... it's really not that hard and it's a clean install if you make it one. just look at the how to in the how to section, the guy does a really clean install.
