For those who have installed cams?
Originally Posted by NTHECRUX
If your really that worried about it you can always donate them to a neighbor.
Really though I think we did everything right when installing them so dont worry. How do you like them any way?
Really though I think we did everything right when installing them so dont worry. How do you like them any way?I am sure the install is correct as well but I just wanted to ease my mind, you know me I don't like unanswered questions in my mind. But if both of us are sure I am doing my best to put it rest. This weekend will be the test to see if we were on fumes that day or not.
Originally Posted by PHILLY EVO
I think you will be ok..... so you can feel a big dif. with the cams......I'm getting ready to do my cams tomorrow can you tell me the are the tourq spec....
You can feel a difference in how the car pulls for sure. I believe it is a great all around mod to benifit everything. The car runs cooler, smoother and more power now and later on after I do my turbo upgrade.
Torque specs. ( This is what I used and it is what evomoto states as well.)
Make sure to note IN-LBS .vs FT-LBS.
Spark plugs 18 ft-lbs
Coil pack bolts: 89 in-lbs
Cam angle sensor housing bolts: 124 in-lbs
Cam angle sensor cover bolts: 89 in-lbs
Cam angle sensor trigger bolt: 16 ft-lbs
Cam bearing caps: 14 or 15 ft-lbs (I used 14.5 ft-lbs
Cam gear bolts: 65 ft-lbs
Cam gear cover: 98 in-lbs
Bolts that hold the main harness to the top/back of the valve cover: 98 in-lbs
Bolts holding the O2 harness bracket to the valve cover: 93 in-lbs
Valve cover bolts: 31 in-lbs
Just about all other brackets connected to the valve cover: 98 in-lbs
EvoMoto's write up on the install that I used for a guide just so I didn't miss anything.
http://www.evomoto.com/tech_info.php?techID=18
Did you install CAM Gears also? How did you do that without having to retime the engine?
Thanks
Thanks
Thanks
This is the method I used. I took my time and it worked out very will.
Hope it helps.
