BOOST controller
Old Aug 10, 2004 | 10:37 AM
UltimateEvo's Avatar
BOOST controller
do u need a boost controller and if u do ..electronic or manual ??...
Old Aug 10, 2004 | 10:40 AM
EVOL 8's Avatar
helps if you want to make more power and maintain boost... elec. or manual- depends how fancy you want to be.
Old Aug 10, 2004 | 10:41 AM
Secret Chimp's Avatar
The car runs perfectly well without a boost controller.
Moving this to the correct forum.
SC~
GReddySetGO's Avatar
You don't NEED anything :P If you want to raise the boost then you should get a boost controller. A manual ball/spring boost controller will hold boost the best and is the cheapest, but you it takes a long time to set and you can't adjust boost on the fly. A manual boost controller will cost you $30-50. Electronics are nice because you can control boost from inside the car and many can save your settings so you can choose diffrent modes with the push of a button. Also some have logging so you can view your runs later. A good one that has a lot of nice functions and holds boost reliabley can be very expensive though, up to $500.
Old Aug 10, 2004 | 10:51 AM
thanks alot
Old Aug 10, 2004 | 11:18 AM
raymerd's Avatar
(1) you don't need anything .. its more a question of want.
(2) I would suggest going with something like the XEDE, more expensive but if you want an effective peformance mod without changing the engine/exhaust, imho, the XEDE is the way to go. The XEDE provides intelligent boost control and much more.
Old Aug 10, 2004 | 12:21 PM
NOVA EVO's Avatar
I recommend the Hallman Pro MBC...it's under $100, easy to install, and holds boost solid as a rock...
Old Aug 10, 2004 | 12:45 PM
4-BNGR's Avatar
$50 MBC's work fine too...
Old Aug 10, 2004 | 09:21 PM
evo81's Avatar
agree.hallman all the way
b1u3
Apr 11, 2016 07:27 PM
ScoobySAM
Jul 22, 2012 08:41 AM
Ct9aGsR
Oct 30, 2007 03:32 PM
upstatescevo
GSC Motorsports - Charleston, SC
Jan 14, 2007 06:20 PM
Evo_Jay
13
Mar 16, 2006 11:55 AM
