Sam's(gofast87) EVO 8 build-up
Old Aug 20, 2004 | 01:49 PM
RnR Racing's Avatar
The complete braking system was that much. Not just the rotors. It is well worth the money if you are serious about road racing.
Old Aug 20, 2004 | 03:10 PM
RnR Racing's Avatar
Let me know what you guys think of the engine bay. We worked for a while getting everything all pretty and nice looking. We are hoping this car will go into turbo or some other mag after it's completed.
Old Aug 20, 2004 | 03:48 PM
statix's Avatar
Just curious, who's going to tune the car?
Old Aug 20, 2004 | 04:09 PM
RnR Racing's Avatar
We are going to be tuning the car tommorrow.
Old Aug 20, 2004 | 04:13 PM
VTECH8TR's Avatar
Nice Setup. Keep us posted on the Power you attain from the Beast .
Old Aug 20, 2004 | 04:24 PM
housedj's Avatar
Thumbs up
looks like a good project. i am wanting to do a Greddy t67 w/a Toda 2.3 stroker kit, cams, stronger timing belt, fuel pump, engine management, etc...
good luck on that!
my evo current mods:
hks spf filter
turbo xs bov (no vacuum or idling issues)
espelir catback exhaust
perrin radiator hoses
perrin upper ic pipe.
blitz fatt dc turbo timer
cusco rear strut bar
cusco rear adj sway bar (set to medium)
perrin sway bar end links
rmr subframe brace
perrin shorty antenna (adds 80 hp hahahaha)
Old Aug 20, 2004 | 04:28 PM
RnR Racing's Avatar
housedj, for the same amount of money you could do a 2.4/GT35R build-up and get much better results.
I will keep you guys posted on the results.
Old Aug 20, 2004 | 04:38 PM
watchout's Avatar
Omg that thing is sick. I plan on doing something similar within the next year. At what rpm does your turbo kit spool up at?
Shane
Old Aug 20, 2004 | 04:43 PM
RnR Racing's Avatar
With an EMS most owners are getting full boost by 4200rpm. The nice thing about the EMS over a reflash set up is that you get rid of the MAS and you can add timing. Both which help a lot with performance and spool.
Old Aug 20, 2004 | 04:51 PM
housedj's Avatar
give me more info on the kit. i want my car to be faster than that mines skyline video where the tach travels so fast it's as if you missed a gear!
Old Aug 20, 2004 | 05:42 PM
RnR Racing's Avatar
complete bolt-in 2.4 bottom end. Bullet proof and ready to go.
The GT35R kit w/equal length manifold is our biggest seller. It works so well and you can make power so easily.
You can find a lot more information on both of them if you do a search. If there are any specific questions on either one just shoot me a PM. I will get back to you asap.
Old Aug 23, 2004 | 09:13 AM
RnR Racing's Avatar
There are a few more new updates with the car. We have decided to build a couple more things to get the car where it needs to be to make big HP.
We are going to build the fuel system to support big HP
Aeromotive fuel pump(1000hp)
-10AN lines, Aero filter, all AN fittings
Fuel Rail
AEM CDI ignition
We are adding these components to give the car the ability to run some crazy boost. We are expecting some big numbers pretty soon. Then the customer will be able to road race and drag race the car. I believe this is also his daily driver so it going to be pretty crazy on the streets of Ca.
Old Aug 23, 2004 | 10:45 AM
EVOeight's Avatar
On your 2.4 liter replacement short block, do you leave the balancer shafts in? What is the redline with that motor?
Old Aug 23, 2004 | 10:49 AM
RnR Racing's Avatar
We remove the balance shafts and do a lot of internal work to the motor. You are basically getting a bullet proof bottom end that can rev to 8500rpm with our head. It works great and we have been reving to 8500rpm for a while now without any problems.
Old Aug 23, 2004 | 10:54 AM
bolsen's Avatar
Looks good RnR. Is that the "polished" manifold that you have?
