can't rev past 4.5k
Old Sep 14, 2004 | 08:48 PM
vletnguyen's Avatar
can't rev past 4.5k
https://www.evolutionm.net/forums/sh...ad.php?t=98594
does anyone know what the two "knobs" are onthe hks eids?
it might be causing the problem, but i cant read japanese
and would like to know if it is a tuning problem.
thanks
viet
Old Sep 15, 2004 | 04:42 AM
areet's Avatar
You have the wires from maf and to ecu reversed. One knob doesn't get used, the other one I set at \ , exactly like that. Almost near the top, but still a bit aways. I'd say the 10-oclock position. Reverse the wires from maf and to ecu, and your problem will be fixed
Old Sep 15, 2004 | 02:12 PM
vletnguyen's Avatar
would that be the white and yellow wires.. where you had to cut the wire in half and connect the eids to both ends?
will try later tonight. thanks
wewtRallywewt
10
Aug 2, 2012 11:33 AM
evo ippo
12
Jan 16, 2007 07:28 PM
