-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   Can the HKS EIDS be used with NON-HKS bov's? (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/106997-can-hks-eids-used-non-hks-bovs.html)
NocturnalEVO Nov 4, 2004 11:43 AM
Was wondering..
Can the HKS EIDS unit be used with other BOV's that VTA, instead of the HKS SSQ?
I was thinking of getting the TURBO-XS RFL BOV since its loud, however it only vents to atmosphere. So I was thinking if it would be possible to run the HKS EIDS with the TurboXS bov?
What do you guys think?
SuperchargedGTZ Nov 4, 2004 12:35 PM
supposedly the turboxs valve leaks at 20 and above psi. silver8evo did a study on most of the common used BOVs today. The EIDS works to smooth out the idle under rich conditions offset by the bov VTA. I mean it isnt like there is an electical connection that goes to the BOV so that the EIDS knows that it is HKS. it will work with any VTA bov.
GreedMOTO Nov 4, 2004 07:50 PM
Direct quote from HKS' website...
"The HKS EIDS has been developed to buffer dramatic airflow meter signal fluctuations. By buffering these fluctuations the EIDS prevents engine stalling or stumbling associated with sudden imbalances in air/fuel ratio of airflow meter-equipped vehicles that utilize atmosphere venting blow-off valves."
So, yes. it would work....but do you really want that BOV? Get something that won't leak.
alex_alex Nov 4, 2004 07:52 PM
Jarod has EIDS.
NocturnalEVO Nov 20, 2004 02:04 PM
Thanks a bunch for the replies fella's, appreciate it.
Whats the loudest vta bov thats available for the evo, that doesn't leak?
NOVA EVO Nov 20, 2004 05:07 PM
The HKS SSQV...it's pretty freaking loud and DOES NOT LEAK AT ALL! {thumbup}
GreedMOTO Nov 21, 2004 09:12 AM
Yup, what he said! :thumbup:
NocturnalEVO Nov 21, 2004 09:40 AM
hmm... doesn't the HKS whistle though? I want something more like a whoosh! type of sound, kinda like how the WRX's sound.
NocturnalEVO Nov 21, 2004 09:41 AM
wat do u guys think about the greddy type-s?
GreedMOTO Nov 21, 2004 12:06 PM
If you VTA your HKS BOV, then you can purchase the optional fin inserts to modify the BOV sound.
http://www.hksusa.com/images_products/S_1272.jpg
memo3 Nov 21, 2004 12:08 PM
I was using HKS EIDS with my hks ssqv set-up and no stalling at all.
It solved the problem however the idling was still rough and some fluttering as well...
