Ft/ LB to IN/ LB Conversion
Just to triple check. 360in/lbs = 30Ft/lbs. Correct? So 180in/lbs= 15ft/lbs. Just checkin. Freekin snap on i got only reads in/lbs. Thanks for any info.
yep
Thanks, can now try to finish the 280 install.
Just use google. :D
I hope everyone knows there is 12 inches in a foot. :lol:
HAHA, funny man. BTW, thanks for posting about bleeding the lifters. No ticking here. Wats the best screwdriver to turn up the idle on TBody? I cant see in the hole. I tryed a stuby phillips but i cant tell if the srew moved or not. Actually im pretty sure it didnt or the idle would of gone up.
You can use either, it is a combo type screw. It's good size so you'd use a #2 phillips.
