-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   Buschur's MAS pipe kit.. (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/140662-buschurs-mas-pipe-kit.html)
BOOSTEZ May 24, 2005 12:31 PM
Dave,
Please explain why you didn't make the MAS pipe to have a nipple that would allow the hose from the boost control solenoid to attach to it like the stock MAS pipe has? I'm not understanding what to do with this hose and what it takes away from the car.
-M
8urv8 May 24, 2005 12:40 PM
Buy a boost controller then you can just cap off the boost control solenoid. You would use a t-fitting to cut into the vacumn line between the bov and the intake, then cap off the nipples on the wastegate, turbo and boost control solenoid. I believe that they say to add one of those small breather filters to the hose otherwise!
4ringturncoat May 24, 2005 12:55 PM
Please don't cap off the wastegate, the boost controller get refrence from the bov feed line (vac/boost), so t into it and run the t-line to the boost control, then out of the boost control to the wastegate.
BOOSTEZ May 24, 2005 03:07 PM
{thumbup}
-M
timzcat May 24, 2005 06:24 PM
It isn't needed. That is just a safe place to connect it so that crap doesn't get in it. It needs to be open but doesn't need to be connected to anything. It is essentially a breather.
