anyone runnin denso 720's making 500whp???
I'm probably gonna run denso 720's with my gt35r setup but I keep seeing people running 880's with gt35r's. 720cc should be good up to 575 whp so if anyone is running around 500 whp let me know if your runnin 720's. Thanks
why not try some fic 750's for better spray pattern and extra hp! 720's should make 500whp, pump gas will be close.
720's will get run over by that 35r. There is a reason why people run 880ccs.
buck up and get 1000cc densos....better safe than sorry right
Have an look here: http://www.rceng.com/technical.htm
500whp? i would think nothing less than 880's would work well on the car
850cc/min is sufficient for 580-600hp.
I guess greddy doesnt sell the 1000cc densos?
With 780cc injectors, pump gas + alky injection, stock fuel rail/regulator, walbro 255hp my car put down 536 awhp on a mustang dyno. The injectors are only around 80% duty cycle.
IE Evo makes 490whp/430ftlbs on 680's: Vishnu Stage 3 with a Garret 30R.
Damn, thats some power.. |
ok so denso 720's should be fine then.
| All times are GMT -7. The time now is 12:25 AM. |
