-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   I'm going to the track tommorow,and have a question!!!! (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/149270-im-going-track-tommorow-have-question.html)
REDEVO1113 Jul 18, 2005 06:16 PM
Just wondering if it is ok to mix 93 octane, with a higher octane race fuel. I do not have time to run my tank dry, and fill it up with high octane race fuel. Also if it is ok, would it even make a diference in track times. My current set up is k&n short ram intake, turboback exhaust no resonators, turbosmart dual port bov, turboxs high performance boost controler set at 22lbs of boost, walbro 255 fuel pump, and a custom dynoflash road tune. Also if all goes well what kind of times should I expect with these mods. Thanx, everybody's info would be well appreciated. :mitsu:
Gruppe-S Jul 18, 2005 06:19 PM
Its perfectly fine for you to mix 93 octane with 100 octane unleaded racing gas. By doing so, your octane level will increase therefore reducing the chance of detenation. You should always run race gas whenever you are tracking your car for higher safety margin. Hope that helped!
Thanks,
Tom
Warrtalon Jul 18, 2005 06:22 PM
Originally Posted by REDEVO1113
Just wondering if it is ok to mix 93 octane, with a higher octane race fuel. I do not have time to run my tank dry, and fill it up with high octane race fuel. Also if it is ok, would it even make a diference in track times. My current set up is k&n short ram intake, turboback exhaust no resonators, turboxs high performance boost controler set at 22lbs of boost, walbro 255 fuel pump, and a custom dynoflash road tune. Also if all goes well what kind of times should I expect with these mods. Thanx, everybody's info would be well appreciated. :mitsu:
Yes, you can mix the fuel...in fact, that's all I do anymore. I used to run the tank empty by disconnecting the fuel return line and putting the pump gas in a tank, but now I just throw in some unleaded 104 on top of my 93 (1/4 tank or so). You won't see as much of a gain as I do, though, because your flash is tuned for pump gas. You should be able to safely turn up your boost above normal (23-24), but you won't get quite the gain that I see with my self-tuning.
BTW, I'd recommend getting some pump gas runs before throwing in the higher octane...
REDEVO1113 Jul 18, 2005 06:23 PM
Thanks for the info tom, that pretty much answered my question. :mitsu: :mitsu:
machron1 Jul 18, 2005 06:32 PM
Your engine gets a lot hotter on the track than the street. I would say definitely run some race gas with a custom tune, but definitely don't run leaded race gas, make sure it's unleaded. Mixing race gas and pump gas is a good idea, you probably don't need to run full 100 or 104 octane. The cost would outweigh the benefits. I would guess a 96+ blend would be perfectly safe to romp on all day even when it's hot out with no adverse affects with your setup. Honestly with the knock control of the stock computer you shouldn't really mess anything up without race gas, but a little race gas is a small investment to get rid of that "what if" factor.
