-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   How many walbro's? (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/154778-how-many-walbros.html)
EVOONYOASS Aug 20, 2005 05:43 PM
How many walbro's?
Runnuing AEM and GT35R pushing around 650whp, will one walbro work or do you need two? What fpr bolts right up to the stock rail?
Should I go another direction with the pump and fpr or is the walbro the easiest?
Thanks!
evo_il8 Aug 20, 2005 05:47 PM
i would run 2 to be safe
EVOONYOASS Aug 20, 2005 05:52 PM
Are you sure or are you guessing? Do you run one in tank and the other inline?
EVOONYOASS Aug 20, 2005 07:35 PM
bump
Jakeg97 Aug 20, 2005 10:48 PM
if was pushing over 600whp , i would get another walbro installed
http://www.automotosports.com/evo_fuel.asp
Turbolover Aug 20, 2005 10:51 PM
1 in tank and 1 in route! dont starve the motor {thumbup} .
platinumspecv Aug 20, 2005 10:52 PM
Yea why dont u just buy AMS's 1200hp fuel system. You wont have any issues for fuel delivery.
evo_il8 Aug 20, 2005 10:59 PM
one in tank and one inline would do the trick
EVOONYOASS Aug 21, 2005 01:19 AM
Cool thanks.
nickracer9 Aug 21, 2005 01:33 AM
where do you get the inline walbro pumps?
nickracer9 Aug 22, 2005 09:41 AM
bump
EVOONYOASS Aug 22, 2005 03:01 PM
bump
alleggerita Aug 22, 2005 03:08 PM
Here's a slick twin Walbro set-up from nasioc.com with both pumps in the tank.
http://forums.nasioc.com/forums/showthread.php?t=830104
Joey B Aug 22, 2005 03:16 PM
I would say it all comes down to this....will the high flow 255lph work?? Try it. Check you AFR's?? What are they telling you? If it looks low enough to warrent another pump inline THEN get one. Don't do all the work and spend the money if you don't have to.
EVOONYOASS Aug 22, 2005 04:47 PM
A guy in that thread mentioned a walbro 310, anybody heard of this and would one of these be able to support 650 whp as opposed to 2 255's? Will it plug into the stock wire harness on the evo?
