Taping sound at 1000-3000rpm's
Hi I have a taping sound with the Car when is fully warmed up by the Camgears with my 272's at 1000-3000rpm's at idle the Car sounds normal no taping sound so could it be lifters or is it normal any advise would be appreciated thanks .
common guys nobody knows ?
did you bleed the lifters when installing them.. there is a huge thread on this..
it happened to my friend once, you have to check it out real fast.
its typical with the 4g63 (especially with cams)... it may go away after time or you may have to bleed the lifters like they are saying
its not typical, its not a normal prob either.. it happens by a collapsed lifter, or not bleeding them when installing cams.. it is normal for people not 2 bleed them though, and then make threads like these..
as i said... its typical, because no one bleeds their lifters... its not normal by any means
| All times are GMT -7. The time now is 04:15 AM. |
