-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   Boost leak or Turbo f'd up? (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/161594-boost-leak-turbo-fd-up.html)
vrrrm...psss Sep 29, 2005 09:48 PM
Well, the car is acting retarded of course. It is very strange the way it is acting, because, you can start driving the car, when the car is cool, and floor it in any gear, make 30 psi of boost and taper to around 20 at redline, then shift to the next gear, and it sounds like the turbo just gives out. It only makes around 10-15 psi for the next gear. Then, after doing that, during the same driving session, the car will never boost past 15 again. Cut the car off, wait a bit, then drive it again, and the same thing happens. It will boost at first, then low boost in the next gear. Anybody have any ideas what the problem could be?
joeymia Sep 29, 2005 09:50 PM
You have been runing the stock turbo at 30psi? If that's the case its probally died on you... :crap:
vrrrm...psss Sep 29, 2005 09:51 PM
^^^^ thats what Im afraid of, but didnt want to hear...lol
AdamsssEvo Sep 29, 2005 11:53 PM
Wwwwwhhhhhhhaaaaaaaaattttt
AdamsssEvo Sep 29, 2005 11:56 PM
were you about to sell evo?
vboy425 Sep 29, 2005 11:57 PM
are ******ing stupid?? the most anyone ever boost is 28 psi and that's on 101 octane. it's not good to boost over 24 psi on a stock turbo anyway, it going to shorten the life, but 30psi jesus, you have just answer your own question. Sorry if i sound harsh i just hated when people mess up a good car.
joeymia Sep 30, 2005 12:08 AM
He wanted to boost 30 psi who cares... he's not that stupid since his engine is still intact. He was probally going to upgrade anyway.
IDRINKV8 Sep 30, 2005 12:11 AM
he is also on alcohol...
vrrrm...psss Sep 30, 2005 12:31 AM
Im on Alcohol man......I dont see why it would mess up a good car. It was tuned for that much boost by Dynoflash, so the engine has no problems whatsoever.
Im not sure yet what the problem would be, but just judging from what you guys have heard, why would the car be able to boost hard 1 time, then no more till u shut the car down?
vrrrm...psss Sep 30, 2005 12:33 AM
Yes, I WAS about to sell it...lol. I got a small problem to fix now though. When I do sell it Im probably going to go back to all stock.
matt55 Sep 30, 2005 08:09 AM
Hi , Iam ******ing stupid also , i do 28+ with race fuel (witch is about the same as 93+alcohol)
Doogie Howser Sep 30, 2005 08:13 AM
Don't post on evom again. (j/k) With alky and a proper tune the turbo can produce more than 24 psi safely. I have not read or heard of turbo failures with a proper tune on alky/race gas at around 28-30 psi on stock turbo yet. Does that mean that the turbo's life will shorten dramtically, well I guess time will tell.
matt55 Sep 30, 2005 08:13 AM
i had the same thing happin to me , the mbc has a small hole to bleed off presure it was pluged up . as soon as let it "bleed" off the extra psi from the mbc to the waste gate it worked fine . AND ALL WAYS DO A BOOST LEAK TEST!!
Bom's Evo Sep 30, 2005 10:24 AM
check your lower ic pipe. Its probably lose or something or getting there. My car was running strong then i popped the pipe off and bent the turbooutlet pipe. Too much boost does that crap. Tbolt clamps are your friends too.
mattsevo Sep 30, 2005 10:31 AM
Let me know if you need a stock turbo. I just bought a TME 20G to replace my stocker. My car has 11K and is bone stock and never raced.
