-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   Do cammed 05's really need a fuel pump? (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/164428-do-cammed-05s-really-need-fuel-pump.html)
Stinkapuss Oct 16, 2005 12:21 PM
I just installed 272's in my 05 and took it on a test run and my a/f ratios are the same as they were with stock cams with the same afc settings. If this is the case then why would I need a walbro?
DCSilvrEvo Oct 16, 2005 12:25 PM
Cause ur STOCK FUEL PUMP will blow up! then what u gonna do?!
Stinkapuss Oct 16, 2005 12:38 PM
John, want to race. :lol: It's Maurice. :D
hawaiievo Oct 16, 2005 02:45 PM
i would get it anyways. its less then a $100 and it takes about 30 mins. to install it. its always good to have the exta insurance.
Stinkapuss Oct 16, 2005 02:55 PM
On my 03 with cams I definitely needed one because my a/f was 11.5.1 with no fuel tuning. There was no way of adding fuel since the pump seemed maxed out. Once I added the pump it dropped down to 10.0.
I have a pump but it seems like the stock one is keeping up just fine on the 05. I will zero out my afc and see what the a/f is then. If it goes to 10.1 then it seems to me that the pump and injectors are fine.
Are there any instances where the stock pump blew on somebody? How are you guys determining that you need a pump?
