-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   don't know if clutch or tranny (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/165097-dont-know-if-clutch-tranny.html)
Stevolution Oct 19, 2005 06:27 PM
I started noticing that when i am driving and i shift into third it sometimes grinds or will be in gear and then kicks the shifter back out of gear and it happens especiialy when i am revving high. does anyone know what might be wrong...if its the clutch or tranny? its an 03 evo with 22000 miles on it...
SiCKlEyWiKeD Oct 19, 2005 06:31 PM
mods?
ACTman Oct 19, 2005 08:28 PM
Try adjusting the clutch for higher release/engagement point. If that doesn't do anything for you, then you have transmission issues. There are a lot of threads on this subject if you have the patience to find them. For adjustment look at:
http://www.roadraceengineering.com/e...utchadjust.htm or http://www.evomoto.com/tech_info.php?tech_id=28.
Nad1370 Oct 19, 2005 08:42 PM
Syncro :( ....worn out hence the grinding and popping out off gear.
Ippatsu Man Oct 19, 2005 10:26 PM
+1 :(
ev08buoy Oct 20, 2005 07:51 PM
I'm not sure if your having the same problem... samething happened to me... it was the shifter cables.. they got rotted from oxidation or something... I got them cleaned and never had another problem.
Stevolution Oct 21, 2005 05:17 PM
I'll have to try to check all the others out.....i guess it could be any problem like syncro or the cables maybe ill just take it into the dealership......still under warranty :P
