-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   Can't locate a DSM ignitor for a MSD DIS-2 (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/167468-cant-locate-dsm-ignitor-msd-dis-2-a.html)
joeymia Nov 2, 2005 02:07 PM
I am setting up a ignition system and was wondering if there was something else I could use besides the DSM ignitor. Is that the only choice I have? Maybe something aftermarket or from another car, gm maybe? So far I have the following parts:
1 MSD DIS-2
2 MSD GM Tower Coils
1 MSD Coil Interface Block
1 MSD 8.5 MM Plug Wires
kcevo Nov 2, 2005 02:34 PM
ebay is your friend, or you can buy a new one from the stealership for around $140
joeymia Nov 2, 2005 03:02 PM
yeah dealership say it will take like 2 weeks. I have called a few. I couldn't find any on ebay either. I am wondering if there is some kind of other ignitor I can use besides the DSM one.
kcevo Nov 2, 2005 03:09 PM
you could for sure. I actually wired up a coil on plug setup using 4 honda ignitors out of the distributors.
joeymia Nov 2, 2005 04:03 PM
you used the honda ignitors on a EVO? I am little concerned about fring the ECU.
sylvester31 Nov 2, 2005 04:09 PM
1 MSD DIS-2
if you need the dsm ones here you go:
http://www.diamondstarmotorsport.com/used.shtml
joeymia Nov 2, 2005 04:48 PM
I love you!!! :chug: If you want you can have sex with my sister.
sylvester31 Nov 2, 2005 06:54 PM
Glad i was of some help, now about that offer...:D .
kcevo Nov 2, 2005 09:56 PM
Not on an evo, but it could be done. With the stock ecu you would only need 2 as there is only 2 coil outputs from the stock ecu. Depending on what coil packs you use, the coil dwell could be off as the stock ecu is set up for the stock Evo coils. Not sure you can even change the dwell with a re-flash either.
Nick@Buschurs Nov 3, 2005 06:26 AM
I believe that you are the one that I talked to over the phone. I can get one for you. Pm me if you would like me to get one for you.
Nick
Buschur Racing Inc.
