-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   Best set up for cam gears & 280's (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/205686-best-set-up-cam-gears-280s.html)
evo8fl Jun 10, 2006 03:50 PM
What's the best set up for evo 8 to drag race with 280 cams -4-2, 0 0? with this mods tbe, fuel pump, flash, forge mbc, drop in filter, turbo smart bov,fidanza camgears, comp cams 280's
Blue Evo 8 Jun 10, 2006 04:34 PM
I dont have the answer you are looking for but do a search for TopSpeeds testing on various 280/280 camgear settings. I went with the +2 INT, 0 EXH setting for best low-end/mid range w/o sacrificing too much top end.. IMHO its the best setting for a car thats daily driven..
GokuSSj4 Jun 10, 2006 06:59 PM
did you have a chance to try +2 intake -1 exhaust ? some peeps had great results.. a little bit of both ... without loosing any tq
miked420 Jun 10, 2006 07:28 PM
im o,o and my car runs great.
Ang Wen Yan Jun 11, 2006 01:09 AM
TTP Cam Gear Setting.
Ted B Jun 11, 2006 02:52 AM
I wouldn't use that setting - too tight an LSA, and too much reversion up top.
For quick spool and BIG midrange torque, but with rough idle - +2/0
For drag racing, where power above 5000rpm is the only concern, I suggest something along the lines of retarding the intake to -3 or -4 degrees, and retarding the exhaust not quite as much, like -1 or -2 degrees. The idle will be smoother, the spool won't be quite as hard-hitting, but the hp peak will be just a little higher and most importantly, broader. This effectively increases average power in the rpm ranges used in drag racing. Greater average power = faster times.
trinydex Jun 11, 2006 03:13 AM
+2i/-1e is basically overlapping the cams a ton more from 00 right?
so your +2/0 is +2i/0e right? that tightens the lsa also right? but advancing the intake cam almost always means more torque and faster spool up right? as the intake valve closes earlier?
retarding intake would make for top end power right? and retarding hte exhaust would do the same but doing it less keeps some lsa? why would you not want to run more overlap with a drag race setup?
Ted B Jun 11, 2006 03:27 AM
+2/-1 drops the LSA from a 110 to a 104 (HKS), which IMO is just too tight for a typical street turbo engine.
+2/0 = +2 int / 0 exh. This gives an LSA of 106 (HKS), which is as about as tight an LSA as you'd want to run. Advancing the intake cam and tightening the LSA increases VE at lower engine speeds. This makes for a big, peaky midrange torque curve when the boost is cranked. The primary downside is the potential for reversion increases as hp rises.
Retarding the intake improves top end power, but as top end power increases, the increasing mass airflow also increases the pressure in the exhaust between the exhaust port and turbine housing. This increases the potential for reversion in proportion to the amount of valve overlap. The ratio of exhaust pressure to boost pressure is the Pressure Ratio (PR). The higher the pressure ratio, the greater the potential for losing power to reversion. This is why with smaller turbo setups, one typically sees a greater PR (e.g. 2:1), and a wider LSA will usually improve the span of the peak power curve. Race engines with late spooling, large exhaust and hotsides will see a PR closer to 1:1, and can tolerate more overlap.
sleet Jun 11, 2006 06:21 AM
I run Ted's +2/0 setting on my 280s and I LOVE the way this car feels. It never stops pulling.
MalibuJack Jun 11, 2006 06:36 AM
When in doubt, stick with 0/0 however, I agree, the +2/0 seems to work best with the fewest downsides.. I left mine at 0/0 for the time being until I get my new setup dialed in..
trinydex Jun 11, 2006 03:22 PM
and the exhaust pr would only get worse with such a setting and a stock like turbo pluggin' things up.
GTREVO Jun 11, 2006 08:42 PM
Ted's +2/0 worked fantastic in my 2.3 litre stroker 2.3 litre.. still does over 600WHP easy but the torque in the midrange is just phenomenal...
TTP Engineering Jun 12, 2006 10:20 AM
Evo8fl has compcams 280/280, not HKS FWIW.
gkania Jun 12, 2006 11:41 AM
What is LSA?
trinydex Jun 12, 2006 01:58 PM
lobe seperation angle
