Evo's with aftermarket o2 housings, roll call
Ok, theres about 100 + threads floating around with o2 housing / boost creep questions so maybe we should get a thread going with specifics to see if we can narrow down what is causing the creep. If people could list:
Boost creep problems? Car year: Brand of o2: Supporting mods: Any adjustments/fixes: Then maybe we can see who is exactly having problems with x mods and y o2 housing and vice versa? |
Mods are not in signature. No boost creep. Put down 306 whp on Tuning Tech's dyno on 91 octane. Drives great, although I think one of my coils is going bad.
What year is the car? Seems the 05/06 are the problematic ones.
05 MR, but maybe the WR turbo makes a difference?
03 Evo with Megan o2 housing, Megan exhaust mani, 3" custom tb, k&n drop-in, 22 psi, and dynoflash custom tune. No boost creep and sounds like a freakin racecar!
now there is 101 threads around. lol. i have a works o2 housing. im waiting to get it back and when i do il let you know.
mods in sig.
no boost creep. ss autochrome 02 housing off ebay, i think its the same as the megan racing/helix unit. |
just installed megan 02 2 days ago, no boost creep.
mods: ams flash,tbe,drop in,boost controller,licp,megan housing. |
Megan Racing o2 on my 06 MR. No boost creep. Only problem was that the holes did not line up correctly. Had to bore two of the holes to make it fit on the stock hotside.
Mods: exhaust, intake box. |
Boost creep? - No problems
Year - 2003 Brand - Works 3" o2 Mods - Works TR-340 kit Works T1R flash White rabbit Nisei IC piping Forge RS DV etc. |
Skilmatic what o2 housing do you have? Interested in what ix's are using with no problems.
Originally Posted by SKILMATIC
thats megan for you hahaha
05 Evo - single flapper 10.5
cams, tbe, intake, fmic, ported mani + hotside, mbc, ebay 02 ZERO Boost creep. My friend with the roughly the same setup as me on his 05 Evo doesn't have any boost creep problems with his Helix 02 either. |
Boost creep problems? NO, i have an mbc and its set at 21lbs
Car year: 2006 IX Brand of o2: SS autochrome Supporting mods: race fmic, licp, 3" dp, cat delete, and exhaust Any adjustments/fixes: when i first got it it would boost higher than i wanted it to so i used an XS 2 stage mbc from my old car to limit it till i had cash for fuel pump, new tune, intake, and Electronic BC |
| All times are GMT -7. The time now is 03:39 PM. |
