-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   Boost leak test problem, 0 psi, doesn't hold (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/213651-boost-leak-test-problem-0-psi-doesnt-hold.html)
Evo#1 Jul 25, 2006 11:18 AM
I have been trying to test for boost leaks all day.
I have been using a tester that I made and a 5 gallon air tank but the damn thing won't hold any pressure.
I have tried every thing, lets just say my engine bay smells lemon fresh and is completely clean from all the soapy water I have been spraying on it.
I have check all the pipe connection, BOV, MBC, FMIC and LICP. I have even tested the tester. :lol:
Is there someting I'm missing here??? :confused: Why won't it hold any air?
It stays at 0 psi no matter how much air I put into it. :mad:
Oh, I have the front end up on ramps if that makes a diffrence...?
I think I'm just not doing it right.
Let me know if you need more details.
Thanks for the help :beer:
justchil Jul 25, 2006 11:24 AM
Where are you putting the testor? I noticed mine was doing this the other day.. my bov was leaking where I removed the pipe that connects to the intake... put my hand over this and it started holding pressure.
Evo#1 Jul 25, 2006 11:27 AM
I put the tester on the turbo where the intake goes.
My BOV was the first thing I tested and its not leaking.
05WhiteEVO8 Jul 25, 2006 11:29 AM
You may be having the same problem I have, the gasket from the hard pipe to the LICP, mine wouldnt hold any pressure either and I had an annoying whining sound. I would check the torque on the nuts and make sure its tight, then try again.
Evo#1 Jul 25, 2006 11:40 AM
This was actually why I tested for leaks, the LICP is such a pain in the ass.
I took the LICP completely off and replaced the stock gasket with a new one that came with the LICP and bolted it down as tight as I could get it with out breaking the bolts.
Then I sprayed it with a **** load of soapy water, still no leak.
It seems this is becoming a serious problem for me.
justchil Jul 25, 2006 11:42 AM
Do you have any vac lines that come in the cabin (boost gauge, ebc etc,,)?
Did you unhook your mbc if you have one? Hmmm this is weird that you can't hear any air coming out anywhere.
Evo#1 Jul 25, 2006 11:48 AM
Yeah I have a boost gauge and it works fine.
I also have a hallman MBC and didn't cap any thing off, but I did Spray it with soapy water.
I just figured I would reach a PSI and then it would start leaking.
justchil Jul 25, 2006 11:55 AM
Yeah that's what mine does so I just cap it off.
It's got to be leaking somewhere or going into the motor hmmm
Evo#1 Jul 25, 2006 12:08 PM
How can I tell if it going into the motor and how do I stop it?
Is there something wrong with my waste gate?
justchil Jul 25, 2006 12:29 PM
well it shouldn't unless if the gas pedal was pushed down.
You may try capping off all vac lines to narrow it down even more... I wish I could help ya out.. it's easier to figure stuff out when it's right in front of you ;)
Evo#1 Jul 25, 2006 04:41 PM
Ok, so I found the leak. It's coming from where the Lower IC Pipe connects to the turbo.
I have one of two problems:
1. The bolts are torqued enough (which is a complete pain in the ass seeing how the bolts are 12mm and the socket is too wide to fit where I need it to :mad: )
2. I need a better gasket. I have a metal one on there right now and I think I need a carbon one.
Let me know what you think.
Thanks for all the help.
boostedwrx Jul 25, 2006 05:30 PM
stock licp or not??
justchil Jul 25, 2006 06:14 PM
Eh ^^ Those should be hex or allen type bolts :\ They are a real PITA to deal with. I put mine on with some sealant + stock gasket before I dropped the entire assembly back in. If you take the alternator off/out it will make things easier.
evil mechanic Aug 5, 2006 09:59 AM
i thought the alternator was on the intake side of the engine? how would removing that help in replacing the gasket on the licp when its on the exhaust side of the engine?
justchil Aug 5, 2006 10:43 AM
Starter not alternator.
