boost test goes straight out exhaust
A friend and I tried last week to do a boost leak test on a tester that I've used in the past with no problems. This time I turned up the compressor to 20psi and my gauge only read around 6psi. Turned it up to 30, it read 8. Turned it up to 40 and almost to 10. He figured out that the pressure was going straight through and out the exhaust. We tried to crank it over to realign the valves over and over and over again, but same result.
Tried again today and same thing. Gauge reads 6 or so and air is coming out the exhaust. Tried cranking slightly for awhile and same thing. Tester is hooked up to turbo, should I try to hook it up to the tb? Any suggestions? |
Your wastegate is broken. Last one I check that went out the exhaust the WG was toast.
Check it. |
Tried again today and same thing. Gauge reads 6 or so and air is coming out the exhaust. Tried cranking slightly for awhile and same thing. Tester is hooked up to turbo, should I try to hook it up to the tb? Any suggestions? Was the motor warmed up and was it at TDC? |
Check it. please ignore that comment dubIX, it has absolutely nothing to do with the wastegate. |
Originally Posted by KevinD
hahahahahaha... riiiiiight.
please ignore that comment dubIX, it has absolutely nothing to do with the wastegate. Yeah, ok. I thought I had a wastegate issue last week and changed it out to the high pressure one from BR. Still the same problem. |
check your egr valve and make sure the hose didn't pop off.
The first time it happened last week, the motor was warm. This time no it was cold. Not sure if it was at tdc. How do I get it to tdc?
With the motor @ tdc at least the intake and/or the Ex valves should be closed , so the presurised air shouldnt be going out the tail pipe. IMO the valves and rings seal up better when the motor is warmed up. Good luck , btw WGA has nothing to do with the air being passed out the tail pipe |
On the harmanic-balancer(SP) there timming marks that line up with marks on the front of the motor , or there is marks on the cams gears/valve cover .
why dont you just cap off the intercooler pipe infront of the TB..? you want find leaking air through the system right?
cap off the throttle body, all that blow through is not good for your seals...
Behind the throttle body there are two vaccume lines. One has yellow dots and the other has green dots. The line with the green dots goes onto a nipple which is on the back side of the TB. You cannot see this nipple, but it is there. My question is what would make this line come off? I am going to put a zip tie on it later today but it is a stock line..... |
