-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   Oil where it shouldn't be (PICS) (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/229732-oil-where-shouldnt-pics.html)
Exciting News Oct 17, 2006 10:30 AM
Doing some work last night (TBA) and saw this. My instinct tells me this may be a result of headstud install (which would bother me since I paid a reputable shop). Am I right? If I am, can retorquing them solve the issue? Just in case anyone asks nothing is coming from the valve cover.
http://i21.photobucket.com/albums/b2...y/IMG_0761.jpg
http://i21.photobucket.com/albums/b2...y/IMG_0762.jpg
http://i21.photobucket.com/albums/b2...y/IMG_0763.jpg
http://i21.photobucket.com/albums/b2...y/IMG_0764.jpg
tony gibson Oct 17, 2006 10:44 AM
Could be blow by....I don't think headstud install would cause this....if you pushed coolant I would lean toward headstud install....Leak down test would be on my list of things to do...Good luck.
idriveanevo Oct 17, 2006 10:48 AM
i installed my studs and there was oil coming from the bottom center on mine...
Pure Playaer Oct 17, 2006 10:50 AM
+1 to the test
tarmac4g63 Oct 17, 2006 10:53 AM
If it was cause of the headstuds it would normally be coolant that you would see leaking you should run a CLT
tripperfx3 Oct 17, 2006 10:54 AM
I dont think blow-by would be that bad... Did you check to see how much oil you might have lost? If it is the headstuds take it back to the shop and have them order you new headstuds and re-do it. You cant just re torque the headstuds. They are designed to strech once you install them. You'll have to get new ones.
vroomevo Oct 17, 2006 10:57 AM
hmm, i have very similar problem. i see oil-like spots just around junction btwn exhuast manifold and engine head. haven't paid much attn to it.
btw, what is the blow by?
tony gibson Oct 17, 2006 11:08 AM
Blow by is when the piston rings are washing out and oil gets past them and makes it to the combustion chamber...Like when you have a catch can hooked up to your crank case breather and it fills up with oil....That is normal crank case pressure....but if it makes it to the exhaust mani, that is bad lol
vroomevo Oct 17, 2006 11:35 AM
:crap:
so, to test for the blow by, then compression test is the way to check it, right?
if there is the blow by, what's the solution to fix? new piston and ring?
how much this will affect the performance?
Az3ar Oct 17, 2006 11:41 AM
Same happened to my older EVO :(. It was the head stud Install.
mchuang Oct 17, 2006 12:51 PM
You could also test for blowby by turning car on and then open oil cap and see if lots of white smoke pours out. Becareful though as oil can jump out slightly too..
tarmac4g63 Oct 17, 2006 12:56 PM
Actually blow by is when combustion gases get past the rings and go into crankcase
Evotech8 Oct 17, 2006 12:56 PM
After the initial headstud install did you heat cycle the engine and then re-torque again to 85 ft.lb?
This is a important step as I've noticed the torque setting can loosen a little after a heat cycle.
If its not too late you might try popping the valve cover and re-torque.
Exciting News Oct 17, 2006 12:59 PM
Hmmmm. No consumption as I can tell. Just changed the oil yesterday, so I'll monitor the level. There was oil in the intake right in front of the turbo. Very little smidge. Blades were dry. I do have a catch can and it was bone dry when I checked it (the clear lines a filmed over and that's it). Some people are saying "yes" to headstuds while others are saying "no".
TTP Engineering Oct 17, 2006 01:21 PM
Looks like headstuds should be retorqued.
