Vendors: 2.1 longblocks?
just wondering if any vendors out there sell a 2.1 liter longblock. i've seen the short block from SBR, but was wondering who else builds this motor as a long block. thanks.
uh just buy a head. SBR is the only people who offer the 2.1 atm
Magnus also opffer 2.1 engine
All you do is use a 4g64 block with a 4g63 crank. And you get a destroker kit.
I have just the block for sale if your interested. --Josh |
Why exactly do you want a 2.1? The two world's fastest 4g63 cars use 2 liters. The quickest EVO8 uses a 2 liter. Why mess with what works and lasts?
well i wanted to step up above a 2.0, but not all the way to a 2.3, while on the stock turbo. i like the idea of power above 8k rpms and i think the long rod concept would help produce a bit more power at this altitude (6000-9000ft). am i wrong? my car is a daily driver but would also be used for autox, drag and road course, as i said on the stock turbo eventually going to a GT30. |
My reasoning for considering the 2.1 is that you get half of the displacement increase of the 2.3 (2.1 is really 2.14 IIRC), without the RPM penalty. I don't plan to rev higher than I do on my 2 liter (8500), but the added displacement is always a good thing by itself. More airflow without raising boost, which is a huge help on pump gas, and the ability to spool a mild to moderately upgraded turbo like stock. I'm not trying to build the fastest or quickest EVO, so what they run doesn't concern me. :) I had excellent results from strokers on the DSMs, but trying nitrous recently I do appreciate being able to rev a little higher than I did on the 2.3s. The 2.1 is certainly an option I am considering for these reasons.
I know a couple guys have gone back to 2 liters, and I believe some of these cases were becuase of failed rod bearings, but were these guys trying to rev to 10k+ with them? I don't see any real disadvantages to using a 2.1, but I am open to suggestions from people that have tried them and switched back. |
Does the 2.1 long rod have a better rod ratio than the stock 2.0?
^ yes it does. THATS why one would want to step up to the long rod 2.1. a better rod ratio is always a good thing, especially if you want any power above the factory redline of 7k. i am NOT a fan of strokers at all, i am a die hard 2.0L guy, but i would and was thinking of running something simmilar to this setup in one of my own cars.
In fact, theres been 2 people on these boards who've had 2.1Ls blow up with VERY little mileage. One being Curt Brown... and Im pretty sure it happened after only a COUPLE runs. Go with the 2.0 or the 2.3.... both proven beyond anyone's standards. BTW, AMS does not have one of the 2 fastest 4G63s. Brent Rau and John Shepherd do... and they both have 2.0Ls. |
SBR's 2.1 has had reported problems. Curt Brown's 2.1 was a SBR short block. I recall that it was rebuilt and sold very quickly on this board.
The Magnus 2.1, on the other hand, is very well thought out, extremely well built, and has not had reported longevity problems. It is not by any means "unproven". It revs quickly, has a beter rod ratio, and has more displacement via bore size, making it closer to a "square" bore / stroke. More displacement is not a bad thing, either. That's why you'd "mess with the nonsense". :) BTW, Magnus owner Marco Passante won the Shootout this year, running an 8 second pass and knocking Buschur's Evo out of the competition. The downside of the Magnus 2.1 is that it's not cheap, which is why, I believe, it's not more common. |
my question for Dave is, why a 2.0 vs. a 2.1?
Originally Posted by joeymia
i thought AMS uses a destroked 4g64?
There is so much misinformation on this board. Curts kit was not a SBR shortblock. His and another member of this board spun rodbearings. Isn't curt still running the 2.1? |
