-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   A'pexi Isamu dyno graphs? (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/242478-apexi-isamu-dyno-graphs.html)
tribe Dec 29, 2006 07:56 AM
I'm looking for some dyno graphs of the Apexi Isamu turbo kit. I've seen a few posts, but no dyno graphs. Anyone?
boostedwrx Dec 29, 2006 12:50 PM
Here ya go - Look for jj_008's post. He had the RX6 turbo kit which is the same as the Isamu I believe.... He made good power.
This dyno reads a little lower than a dynojet.
https://www.evolutionm.net/forums/sh...d.php?t=186602
tribe Dec 29, 2006 03:14 PM
Thanks! I posted the question on the other thread, but in case JJ doesn't reply, do you know if any runs were on pump gas, and if so, how much boost?
jj_008 Dec 29, 2006 06:39 PM
~400hp on pump at 23psi and ~500whp at 34psi.
tribe Dec 29, 2006 09:16 PM
JJ - thank you for the info.
Bioxide02 Dec 29, 2006 11:26 PM
^^ On a super safe tune as well.. I own the car now..
Should be seeing bigger numbers shortly. Going to go with a stroker motor and run aem+meth and see what the turbo kit can really do.
Warrtalon Dec 29, 2006 11:33 PM
It won't make as much power on meth as race gas, so don't get too excited. The stroker will increase torque and mid-range, but it won't give a big HP gain.
Bioxide02 Dec 30, 2006 11:23 AM
It will also allow me to run a more aggressive tune without having to worry about the motor....So the hp will go up. And the race gas that was used to run 504 awhp was just 100 octane unleaded. Not C16.
