Why Don't People Use The Hks Ssqv???
I heard that the Super Sequential wasn't a good BOV for Evos..... anyone know why?:confused:
i use it, n i love it, but the reason most ppl dont use it is because if you keep it vta, it knocks off your maf sensor n messes up the air flow readings, making your car think its gettnig less air then it actually is (I believe?) there for causing your car to sputter under partial throttle. also when sitting at a light it can cause your car to sputter n sometimes the rpms drop down below where tehy should b, sometimes causing the car to stall
all u need to do is recirc it, with the recirc kit and ull b good to run lots of boost |
Sweet...a great chance to use my flame suit that santa brought me.
https://secure.buschurracing.com/cat...roducts_id=716 |
Search and you will find out How,What,Where and Why.
for me it works great with stock turbo VTA... now running 2.3 and 35R and no problems either :)
Originally Posted by Pure Playaer
(Post 3816340)
Originally Posted by hotrod2448
(Post 3816389)
You've got the effect backwards. The MAF already metered that air that gets vented to atmosphere and the ECU injects fuel for it but, because the air obviously isn't going through the motor anymore it goes pig rich and stumbles.
damnit.. |
partial throttle sputter is surge, tight valves can cause that. Hotrod is correct. I use the valve and its great however i think i will be switching to a Tial very soon b/c i hear even the HKS valve can't hold high boost pressures that well.
50mm TIAL FTW!!
I have and I love it
Stock ECU, VTA and no problems |
People always claim no problems, but most of the time they don't even know it's causing problems. It's really bad, because then noobs think it's ok to get it, which is very discouraging...
(Post 3817096)
Its not bad at all depending on the setup you currently have. Stock/ish evo, yes bad, between the rich conditions and surging i would stay clear of it.
unless you use a GM MAF translator you will run into problems. Still better to keep the recirc. IX BOV IMO is the best you can get. or the WORKS DV
part throttle surge on the HKS BOV sucks...
| All times are GMT -7. The time now is 04:48 AM. |
