What are you afr's on pumpgas?
As the title states...
What are the tuners tuning to for best power and safety margin? |
its different on the pump gas 91 93 94 and it also varies on mods and aggressiveness of tune...
Originally Posted by binh
(Post 3963471)
well we have 93 here in louisiana,the afr varies.cruising its 14.5 to 14.6 at wot true the gears 11.0 to 11.3 and sitting there on idell its 12.5 to 12.6
I wanted to know on 93 octane..
Originally Posted by evo_08
(Post 3963512)
The reason I asked is bc it seems like everyone is tuned very conservatively. Mine hits 11.9ish at WOT.
I checked the aem log and my counts of knock never exceed 1 and the timing is right around 7 degrees... any input? |
(Post 3964088)
I checked the aem log and my counts of knock never exceed 1 and the timing is right around 7 degrees... any input? 1. Did you calibrate your wideband sensor lately? Does your wideband throw an error if your sensor is dying? 2. The 7 degrees of timing is @ what RPM? Give us a breakdown of your timing by rpm please. |
(Post 3964088)
any input? Eric |
(Post 3964088)
I checked the aem log and my counts of knock never exceed 1 and the timing is right around 7 degrees... any input? 11.9 seems kinda high on pump but I would try to contact your tuner and let him know whats going on w/ your car |
Originally Posted by nj1266
(Post 3964201)
A few questions:
1. Did you calibrate your wideband sensor lately? Does your wideband throw an error if your sensor is dying? 2. The 7 degrees of timing is @ what RPM? Give us a breakdown of your timing by rpm please. 2. timing is 4k=13 5k=13 5k=7.9 6k=7.9 at WOT |
10.9...93 octane
(Post 3964088)
I checked the aem log and my counts of knock never exceed 1 any input?
Originally Posted by EVO8_PR
(Post 3964990)
What parameter are you logging?
| All times are GMT -7. The time now is 05:46 AM. |
