-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   The cause of my TC's whine. (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/262513-cause-my-tcs-whine.html)
zze-131 Apr 6, 2007 12:48 PM
So my TC obviously is whining but I'm curious if what I did played a part in its death whine.
First off... The car has roughly 125,000 miles on it. It has been driven on lower boost since 60,000 until just recently when it was finally fixed. The car has never been taken to a strip, street raced, or really abused. I've changed the TC oil with the proper factory recommended 90w oil and to the right levels. The car has the original clutch.
Secondly... this is where I'm unsure... I have installed Buschur front and rear solid plastic motor mount inserts and a Energy Suspension rear carrier bushing. The engine mount bushings were installed months prior and the rear bushing a few weeks ago.
As timing would have, The day AFTER I got the boost back to factory levels again is when the TC started whining. Do you think its a combination of the power coming back after a long time and the bushings, one but not the other, or just something that happens (coincedence).
I might add that driving the car for that long on reduced boost was torture. I plan on posting my process soon (probably this weekend).
TeStUdO Apr 6, 2007 12:59 PM
Slightly off topic, but I see you are in Springfield. Where do you commute to work to put on that many miles?
D-VO Apr 6, 2007 01:00 PM
Hey just a quick question. Does yours whine at partial throttle as well?
Curt@MrLed Apr 6, 2007 01:09 PM
your above mentioned things have nothing to do with the t/c whining... you prob just didnt hear it before...
zze-131 Apr 6, 2007 01:51 PM
Thats pretty much what I'm looking for. The car is incredible with all the bushings and suspension work. I don't want to have to undo it because it killed a TC.
As for hearing it before. It was silent one night, to louder than volume level 49 the next.
Also. I commute mostly to Falls Church but I do a lot of driving, in and out of VA.
Zeus Apr 6, 2007 01:54 PM
It's an 03'... suprised it took that long. Seriously, I could be wrong, but I believe the 03's had the worst track record (no pun) of all the USDM Evos.
