IX Engine idle noise (belt?) (video)
Anyone else got this noise? Sounds like noise came from the belts (or at least coming from that side of the engine). Car/engine is stock... noise started around a week ago. Only thing I think can of is that overfill the engine oil a little bit. Edit from llDemonll: Additional video with the noise in better quality |
hrm...i have a sound like that but, mines sound like metal on metal, like a RING
overflowing engine in oil is REALLY bad. make sure your not past the full mark |
Originally Posted by Clutchdc5
(Post 4184329)
you create to much crank pressure theres only so much oil it can hold till it has to be pushed out of somewhere
you'll get degraded performance and as stated above, too much pressure built up in the motor. eventuallly the oil will find somewhere to go.
That sounds like your timing belt or pulley (or crankshaft).
It's definitely something turning with the crankshaft. -M |
hey, i have the same sound too.
in the morning (engine are cold) sound like old belt, when its hot noise goes away. So, i change the crankshaft belt, after that still have the same sound. but goes away when the engine is hot! i dont know!:confused: more info PLEASE:cool: |
Not sure about cold.. but mine is there when the engine is warm/hot. :confused:
Originally Posted by JT-KGY
(Post 4184351)
How is it really bad? Other than the fact that manual says not to do that?
The sound I hear sounds like either some loose metal or a bad bearing. |
I have the same sound, my just had a few mods. it on and off even when engine hot.
my IX does it too... im guessing its common
same sound as my car, though mine seems more intermittent. I'm finding more and more to ignore minor sounds with this car...hey, it's a mitsubishi, right?
Thanks guys.. so maybe it's common... mine started to have the noise just
last week.. around 12k mark. Car drives fine though. |
Thanks for the info on the overfill too... I'll make sure I wont overfill again on the
next oil change. |
I listened more closely today.. really sounds from one of the pulleys or belt...
How involved is it to remove/replace those? Thanks, |
