So...who's mixing in a couple gallons of E85 with their premium?
I've read that some folks are doing this. I have a Works P2r 93 octane flash in my Evo and the number of gas stations with 93 are getting harder to come by in my area, but there are a lot of E85 pumps. I've read that some are mixing a gallon or two of E85 in their cars at fill-ups to add some octane. I've read quite a bit about E85 and know that you need a tune, injex, etc to run it straight.
I'd love to be able to mix in a couple gallons to bring my octane up to 93+ to eliminate knock. Who's doing it, and how's it working for you? My current tune is for 21lbs of boost, and it has ~11.5:1 AFR (dyno verified). |
its very hard to mix e85 with pump gas, unless you know exactly how much e85 is in the tank..
i did a mix of 80/20 of 80 percent e85, and my wot a/fs were running around 11.0ish... the same tune, i put 100percent e85, wot a/fs went to around 12.0ish |
Are you sure people are doing that without being tuned for it. It's not the same as adding some high octane (100+) for knock suppression. E85 requires SIGNIFICANTLY more fuel, so I'd be concerned with how a mix of E85 and 91/93 works on an 11.5 AFR tune...
Good question, I've been wondering this also. I've heard you
you can run up to 25-30% mix without a problem but have yet to verify it. I'd like to mix a couple gallons just to offset race gas cost for a little insurance on track days. |
I've read you need to flow 30-40% more E85 to equal gasoline if your
running it straight. A local guy has a 1G eclipse running straight E85 with the Bushur twin fuel pump set-up and 1000cc injectors and at the 450whp power level the injectors are about maxed. |
Originally Posted by Mike01gsr
(Post 4197919)
running it straight. A local guy has a 1G eclipse running straight E85 with the Bushur twin fuel pump set-up and 1000cc injectors and at the 450whp power level the injectors are about maxed. Yep, that's common knowledge . I'm not talking about running it straight though. |
yea most people get 1600cc injectors for running e85...
Originally Posted by KrisR
(Post 4197939)
Sorry that was more of a responce to some of the other posts. I know what your asking and am wondering the same thing. I will have my wideband installed soon, could always put in a couple gallons and see how it effects AFR. Is there a way to calculate the octane to see if 4 gallons or so on a full tank would actually raise the octane? |
(Post 4197982)
asking and am wondering the same thing. I will have my wideband installed soon, could always put in a couple gallons and see how it effects AFR. Is there a way to calculate the octane to see if 4 gallons or so on a full tank would actually raise the octane? EDIT: (again using simple math, which might not apply here), the above scenario would lean the car out to around 12.2:1 AFR (40% x .17 = 6.8%. 11.5 + 6.8% is around 12.2) Probably not the safest I guess. |
I wouldnt do that either especially if you have all your stock fuel lines in place. E85 is very corrosive
Leans out the car because its E85, yet raises octane. Hmm.... this is an interesting one.
Originally Posted by kreionic
(Post 4198010)
Originally Posted by Liqquid
(Post 4198015)
(Post 4198010)
-Paul |
Originally Posted by PVD04
(Post 4198316)
That is not true. Methanol is very corrosive. Ethanol is moderately corrosive. E85 is slightly corrosive at worst.
-Paul Im on my 5th tank of gas running E85! I only get about 14mpg though.. but that was compared to only 18mpg with 93 octane. |
| All times are GMT -7. The time now is 03:42 AM. |
