Fuel Pressure Regulator Install?
Does anyone know or have any instructions on how to install a Fuel Pressure Regulator. Iv'e looked but I just cant find any. thanks for the help.
Cant be too bad,
remove regulator bolts remove regulator take smoke break wipe up gas install regulator install regulator bolts torque them to spec with the value posted in the "how to" section or FS manual purchaced at ebay for $8 |
stock or aftermarket?
The install will depend on what regulator you get, what fittings you have, etc. I just installed an adjustable setup from AMS, and it's straight forward if you have all the needed parts. |
useless mod
not useless if you are planning on going with a very big set of injectors. Having adjustable static fuel pressure is good tuning tool, when the set-up calls for it.
CJ |
Originally Posted by blockhed79
(Post 4227925)
useless mod
Fully Built motor, head, upgraded turbo kit, fuel system etc. its like 450hp. The last thing i need to do is upgrade the Fuel Pressure regulator. I just dont know how to do it. i wasn't the one the took it off so i dont know where it goes. do I use all three ports??
Originally Posted by jdmrally
(Post 4228536)
Yeah Its an aeromotive FPR thanks for the help
1 Attachment(s)
yes, that's right basically. But looking from the front of the Evo at the engine bay, your supply and return are on the wrong ends of the rail. The Evo rail is supplied on the drivers side, and the return is on the passenger side.
Check out this link to a pic of AMS's setup. Hopefully it will give you some orientation on how it's hooked up, use the white handled oil dipstick as a reference point. It's a different regulator, but basically identical to the Aeromotive http://www.amsperformance.com/store/...n_DSC04937.JPG |
2 Attachment(s)
Ahh that makes so much more sense now!!! Thanks! :-)
1 Attachment(s)
Hi, that is the connector for the vacuum line.
