BIG HP EVO'S-Wheels & Tire Choices
You guys out there with the big hp evo's what size wheels are you running and what is your tire of choice.
22in Spinners w/ Advans
spinners are tight {thumbup}
Originally Posted by EvolutionBoy67
(Post 4323979)
I assure you 99 percent of the "big" hp evos have ****ty wheel and tire setups. Scorke |
i'm currently on 18x8.5 volks.. fixing to go to 17x9 rota's with nitto's
18X9.5 Volks... 275/35 BFG drag radials.
for my bling status i have ADVAN and for track i got ROTA.
Im going to get one pair of rims with ultra-summer performance tires and put winter tires on the stock rims. My question though is do the guys with 500, 600, 700hp evo's run 17's or 18's and whats the pro and cons of running each with such high hp. I want 18's but if 17's give better performance such as putting the power to the ground much better than ill get 17's.
17x8 rota
255/45 kumho mx 15-20psi, i hook up on the street with 6k launch, little higher on the track =-) sticky with soft sidewall, but still firm enough to handle nice |
My street setup is Volks CE28N 17X9's with Nitto 245X45 555R Drag Radials. In early January, I ordered a custom set of 15 inch Volks CE28N's. They weigh 9.2 lbs, but as of today, they still haven't arrived. These were for Drags only. One of the main reasons that I still haven't run the car at the track. Other reason is cage, but I'm meeting with a cage builder next week.
I got 3 rim choices in mind but i will be rocking a 17x10 with 275 or 255 denpending on rim for the street and slicks for the track.
Originally Posted by jmartinez1170
(Post 4326025)
Scorke |
| All times are GMT -7. The time now is 03:38 AM. |
