EGT probe placement
This has probley been covered but what the hell, got the EGT gauge but where is the correct spot to drill the whole for the probe? Different people have different ideas so I don;t know which is the correct way? Chime in quick, it's a kickass day here and I need to get out and work on my Evo. :spin:
Thanks Bros |
Slackers. :spin:
hey i dun have an evo but i heard they already have a pre-drilled hole on top of one the header. i think you just unscrew a screw and screw ur pobe in. hope this helps.
No ****. Well damn, let's go check it out shal we?
careful of the swarf getting into the impeller housing when you drill it out
I see no pre-drilled hole anywhere. So just drill a hole through heat sheild and the header huh.
well look at teh pic and where its pointing. if there isnt a hole there then u might have to unscrew and drill one urself. but i clearly remember reading that that person didnt have to drill.
That's my picture and I had to drill.. no such tapped 1/8 NPT hole exists
Originally posted by KK I think most have been tapping into #1: https://imagehost.vendio.com/preview...e1223/eng1.jpg Mark Thanks Eric |
He might've drilled the hole while the engine was running, so it would blow the chips out.
Originally posted by ru4real He might've drilled the hole while the engine was running, so it would blow the chips out. Yes I have seen that done. But not everything is cleaned even thow. I also see a magnet take up most of the metal but still not the most ideal way. |
