| outlaws69 |
Jul 13, 2007 09:28 AM |
can't boost over 16psi, WHAT?
So, about two weeks ago, I noticed my car have lost a bit of power.:( First I was worried but because it wasn't really a big lost, I thought it was just weather (Seattle has been it the 80s)... A few days later, Blam... car was driving like a POS. I couldn't boost over 16 PSI (I do about 25-28 normally) so I was like I broke something.:crap: At first I thought it was my piping got loose so I checked everything, upper lower front back nothing... ??? So, I thought my boost control is dirty. Cleaned it out and check connection put it back in... nope still doing the same thing. At this time I said to myself I might have broke my turbo but I went on and checked everything else because the turbo is just too expensive to brake... so I checked all the plugs and wire, the fuel system, even to my ARC air box out and cleaned that. still nothing. So I put everything back together and thought I might have blow some kind of gasket, like the exhaust or head something is leaking right? No love. everything looks good. and so for one week I was driving my car like that 14 psi, got picked on by cars that I normally won't ever consider playing with. So, the following weekend, I look deeper took everything back apart and I realized I have missed looking at the coupler on the upper pipe. It has a cut on the bottom of it from rubbing against a bracket and the engine heat has dried out most of that... I guess I am writing this so if you run into the same problem, you might want to check the couple... hope this help!:mitsu:
Watch someone is going to come out and say something like I would have checked it first thing... Whatever.
