-   Evo Engine / Turbo / Drivetrain (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain-22/)
-   -   Need help, car won't start after breaking Exhaust O2 sensor (https://www.evolutionm.net/forums/evo-engine-turbo-drivetrain/298281-need-help-car-wont-start-after-breaking-exhaust-o2-sensor.html)
tork Sep 27, 2007 07:11 PM
hey fellow members. before i start going crazy replacing everything to fix the problem, i need some opinions.
it's a 2003 EVO VIII...
here's the story
i rolled over a small tree stump i didnt see. scraped my exhaust from the cat to the mid pipe. heard a thump, and car dies. try numerous times to restart it and nothing.
the only damage i see is the O2 sensor on the exhaust mid pipe which was cracked. no other damage to under body of the car what so ever.
so i replaced the O2 sensor thinking that would fix the problem. that wasnt the fix. now it still wont start.
i started thinking maybe the spark plugs went bad. but not sure if thats the problem.
anyhow i dont want to make it any longer, so what other things can contribute to this problems incase i'm over-looking something.
your insights would be greatly appreciated :helpme:
dsm25psi Sep 27, 2007 07:19 PM
If that was the only damage done make sure your wire to the o2 sensor are not damaged or ripped apart, if you hit something hard enough to brake the sensor you defiantly want to check the connections.
RoadSpike Sep 27, 2007 07:39 PM
Probably shorted the heater wires and blew the fuse to the computer.
Check all your fuses :)
tork Sep 27, 2007 07:41 PM
i replaced the entire O2 sensor harness n all. n it still aint starting. pretty confused how the car wont start.
i looked up and down the entire underbody after replacing the sensor to see any other damages, and nothing. hmmm
RoadSpike Sep 27, 2007 07:43 PM
you did check your fuses right?
tork Sep 27, 2007 07:44 PM
road spike, i started thinking about maybe a fried ECU as well or like u said, burnt fuse. i'll check again
RoadSpike Sep 27, 2007 07:46 PM
Remember there are 2 fuse boxes one under your steering wheel and one under the hood.
tork Sep 27, 2007 07:50 PM
crap i forgot to check the fuse box under the steering wheel. i'll do that in the AM as well
tork Sep 28, 2007 04:11 PM
just an update to my problem
new O2 sensor + 20A fuse = my car starting again.
thanks for your help guys, much appreciated
